Pwm 16f876a
Results 1 to 9 of 9
Thread: Pwm 16f876a
    Jun 2005
    Wisconsin
    Default Pwm 16f876a
    I recently moved a project from a 16F88 to the 16F876A to gain more I/O. Previously the contrast of the LCD was controlled via PWM on CCP1, which worked perfectly. Since moving to the larger PIC I added PWM control of the backlight and can't get either to work.
    I have set everything up the same way and have all the defines correct. I have reread Melanie's post about backlight and contrast control. I have no clue where I'm going wrong. Help?
    ; -----[ Fuses ]----------------------------------------------------------
    @__config _HS_OSC & _WDT_ON & _PWRTE_ON & _LVP_OFF & _CP_OFF
    ; -----[ Setup ]----------------------------------------------------------
    ADCON1=%10000110 ; Turn on A/D AN0 - Digital for the rest (16F876A specific)
    CMCON=%00000111 ; Disable Comparators
    TRISA=%11100001 ; PORTA Output/Input settings (1= Input 0=Output)
    TRISB=%00000001 ; PORTB Output/Input settings (1= Input 0=Output)
    TRISC=%10001000 ; PORTC Output/Input settings (1= Input 0=Output)
    OPTION_REG.6=1 ; INTEDG rising edge=1 falling edge=0
    T1CON.4=1
    T1CON.5=1
    ; -----[ Defines ]----------------------------------------------------------
    DEFINE OSC 20 ; 20 mhz XTAL (change notes above)
    DEFINE I2C_SLOW 1
    DEFINE HSER_BAUD 9600 ; 9600 Baud USART
    DEFINE HSER_RCSTA 90h ; Enable USART RX
    DEFINE HSER_TXSTA 24h ; Enable USART TX
    DEFINE HSER_SPBRG 51 ; 9600 Bauds
    DEFINE HSER_CLROERR 1 ; Clear all USART errors as they happen
    DEFINE LCD_DREG PORTB ; LCD 20x2
    DEFINE LCD_DBIT 4
    DEFINE LCD_RSREG PORTB
    DEFINE LCD_RSBIT 3
    DEFINE LCD_EREG PORTB
    DEFINE LCD_EBIT 2
    DEFINE LCD_BITS 4
    DEFINE LCD_LINES 2
    DEFINE LCD_COMMANDUS 2000
    DEFINE LCD_DATAUS 50
    DEFINE CCP1_REG PORTC ; HPWM 1 pin port
    DEFINE CCP1_BIT 2 ; HPWM 1 pin bit
    DEFINE CCP2_REG PORTC ; HPWM 2 pin port
    DEFINE CCP2_BIT 1 ; HPWM 2 pin bit
    what happen if you remove
    Since this PIC don't have alternate pin for any CCPx, i don't know how it's handled.
    And the obvious, if i can... did you really selected the right PIC in the editor?
    Also, you should have a space between @ and __Config. But it could be a forum copy/paste problem so..
    Also, even if not PWM related
    You have two definition of the Baudrate... one is false. Or you keep HSER_BAUD 9600 or you correct the HSER_SPBRG 51 to HSER_SPBRG 129. 51 is the right value for 8MHZ.
    Jun 2005
    Wisconsin
    If I remove the defines I get the same results, which is nothing.
    And yes, 16F876A for CodeDesigner Lite & ICProg.
    mmm how about the frequency? @20MHZ the minimum should be 'round 1.2KHZ if you're using HPWM.
    Jun 2005
    Wisconsin
    Here are the subs I'm using.
    ; -----[ LCD Contrast PWM ]-----------------------------------------
    PWM_Contrast:
    value=Contrast*40
    HPwm 1,value,1000
    ; -----[ LCD Backlight PWM ]----------------------------------------
    PWM_BackLight:
    value=Backlight*51
    HPwm 2,value,1000
    As i said, the minimum frequency should be 1.2Khz. 1.3KHZ work fine here. So change it to...
    PWM_Contrast:
    value=Contrast*40
    HPwm 1,value,1300
    PWM_BackLight:
    value=Backlight*51
    HPwm 2,value,1300
    About now?
    Jun 2005
    Wisconsin
    Of course, you are correct changing to 1300 worked. Which, now that I think about it, makes sense because I was using the internal 8mHz clock on the 16F88.
    Thanks for the help, its my first time with PWM. Needless to say I will remember this in the future.
    I may ask Melanie to make a note about this in here FAQ.
    So my guess in the previous post #2 about SPBRG value was correct. You should modify it NOW!
    And... the minimum frequency range is stated in the PBP manual... OUPS!
    Glad to know it's working now.
    Have fun!
    Jun 2005
    Wisconsin
    I did the RTFM thing and saw the chart. I just didn't make the link mentally between the chart and my code. I will in the future.
    Thanks!
  1. Half-bridge PWM with a 16F684 ?
    Last Post: - 17th January 2010, 23:18
  2. Variable PWM PIC18F2431
    By trr1985 in forum mel PIC BASIC Pro
    Last Post: - 12th June 2009, 07:03
  3. PWM setting PIC16F887
    By Gevo in forum mel PIC BASIC Pro
    Last Post: - 12th June 2008, 08:24
  4. 16f876a Pwm
    By Hainkm in forum mel PIC BASIC Pro
    Last Post: - 30th December 2007, 18:33
  5. Tidying Up PWM Routine
    Last Post: - 21st February 2005, 01:26
