PWM problem CCP2 port
Results 1 to 11 of 11
    In the binary world, multiplying by 2 is the same as shift left 1 (<< 1).
    This will always leave a 0 it the bit0 location. So if you had a dutycycle of say 257 (100000001), * 2 would be 514 (1000000010).
    The easiest way to fix it is to just use bigger numbers. 10-bit numbers range from 0 to 1023. <br>
    I've added:
    ADCON1 = $0F
    But still ccp2 doesn;t work (also on portc.2 it gives problems)
    The pin is always high.
    And correct me if i'm wrong but when i don't make a loop in the program i get no response on any pwm port
    So i need the Goto mainloop
    Did you also change the CCPMX configuration fuse for RB3/CCP2 alternate?
    portc.2 is CCP1, are you saying that that one stopped working ?
    And yes, you need to have a mainloop. Otherwise it goes to the END statement and enters Sleep mode. But changing the CCP registers doesn't need to be in the mainloop.
    it's working thank you very much!
    Oke when change the value to 1023 what to do with the >> 2 value?
    It'll stay the same as you had it before. As will the
    CCP?CON.4 = Duty?.0
    CCP?CON.5 = Duty?.1
    Unless I'm missing the point of the question.
  1. Variable PWM PIC18F2431
    By trr1985 in forum mel PIC BASIC Pro
    Last Post: - 12th June 2009, 07:03
  2. PWM Problem
    By cihhan in forum mel PIC BASIC Pro
    Last Post: - 14th June 2008, 19:43
  3. PWM setting PIC16F887
    By Gevo in forum mel PIC BASIC Pro
    Last Post: - 12th June 2008, 08:24
  4. Problem with A port on 18F2550
    By NL2TTL in forum mel PIC BASIC Pro
    Last Post: - 9th May 2007, 23:59
  5. Microcontroller with 2 way paging application problem
