PWM problem CCP2 port
Results 1 to 11 of 11
Threaded View
  1. #3
    NL2TTL,
    Seems everyone is forgetting the analog ports these days.
    ADCON1 = $0F
    Added: It will probably be better to have subroutines that set the dutycycle of the CCP modules. Then call them only when needed.
    Continually setting the registers in the main loop may cause some problems, and isn't needed since the hardware will continue putting out the PWM while the main program is doing other things.
    Also, by using these statements Duty3 = Gval *2, it effectively reduces the PWM resolution to 9-bit since bit0 will always be 0.
    Added2: The RB3/CCP2 pin is the alternate CCP2 output. You'll need to change the CCPMX configuration fuse for it to work there.
    Last edited by Darrel Taylor; - 18th September 2006 at 19:48. Reason: Coffee first, answers later :)
  1. Variable PWM PIC18F2431
    By trr1985 in forum mel PIC BASIC Pro
    Last Post: - 12th June 2009, 07:03
  2. PWM Problem
    By cihhan in forum mel PIC BASIC Pro
    Last Post: - 14th June 2008, 19:43
  3. PWM setting PIC16F887
    By Gevo in forum mel PIC BASIC Pro
    Last Post: - 12th June 2008, 08:24
  4. Problem with A port on 18F2550
    By NL2TTL in forum mel PIC BASIC Pro
    Last Post: - 9th May 2007, 23:59
  5. Microcontroller with 2 way paging application problem
