PC to PIC via RS232
Results 1 to 4 of 4
    Jun 2006
    Question PC to PIC via RS232
    Hi
    Ich have a problem.....I want my PC to comunicate with my Pic...
    Between the Pic and the Pc there is a Bluetoothmodul and a Max232....The Software configures it as a Com Port......I connected the Max232 with the Pins RB1/RX/DT to receive and the RB2/TX/CK to send commands.....But with my computer I only receive € and other french signes.......
    My Code to send a command to the Computer:
    SerOut 2, N2400, ("a")
    My Code to receive a command from the PC:
    SerIn 1, N2400, (B0)
    if Bit0 = 1 then Comand_1
    if Bit1 = 1 then Comand_2
    Martin
    DiGGi's Avatar
    DiGGi Guest
    hi,
    I had the same problem.
    Try to check B0 insted of the seperated Bits.
    Diggi
    MIIIIP bad answer. If you have a MAX232 between your PIC and your PC you must use the True mode in SEROUT
    SerOut 2, T2400, ("a")
    psst there is nothing french in the character you see.. trust me
    Ca c'est du francais stie!
    Jun 2006
    Talking Hi
    I solved the problem I donīt know how but itīs working now.....Here is one of the signs I received before: ā or € etc....
    thx
    Martin
  1. Send data PIC to PC
    By konter in forum Off Topic
    Last Post: - 25th December 2009, 23:04
  2. Replies: 67
    Last Post: - 8th December 2009, 03:27
  3. HSERIN & Interupts (aka controlling PIC programs from a remote PC)
    Last Post: - 17th June 2009, 15:46
  4. RS232 into 2 PC ports
    By manxman in forum mel PIC BASIC Pro
    Last Post: - 30th August 2008, 14:33
  5. PIC18F4680 to PC via MAX232 (RS232 serial) no output
    By opticsteam1 in forum mel PIC BASIC Pro
    Last Post: - 14th April 2008, 21:39
