Programming IC2 24LC256
Results 1 to 13 of 13
    Well maybe you just forgot, it have been discussed many times.
    I2CREAD,I2CWRITE, SERIN, SEROUT, etc etc, are software solution. AND allow you to use the pin you want. It's no coincidence why you can choose your favourite pin.
    HPWM, HSERIN, HSEROUT use the internal Hardware AND don't allow to choose specific pins (except for alternate CCP pin in HPWM)
    Mar 2006
    INDIA
    Default This is also simple 24lc programmer
    This is also simple 24lc programmer without extrnal power ,with icprog.
    That's a little more than 2 resistors. But it looks like it might be a little safer with the voltage clamping.
    Hmmm, self powered too.
    I think I'll try it.
    You could save few component by using the USB 5V. I already built this interface with USB power and used IC-PROG AND/OR PonyProg for the on-the-road radio decode service. Worked well before i did the decode dongle.
  1. Data Programming Error at 0000
    By cpatnoi in forum mel PIC BASIC Pro
    Last Post: - 22nd May 2009, 03:37
  2. Problems programming
    By Lionheart in forum General
    Last Post: - 7th December 2008, 16:51
  3. PIC programming algorithm - where is it to find?
    Last Post: - 24th June 2007, 18:31
  4. Some questions for programming
    By fnovau in forum mel PIC BASIC Pro
    Last Post: - 5th July 2006, 16:04
  5. MELab Programming
    By tarr in forum mel PIC BASIC Pro
    Last Post: - 22nd March 2006, 13:36
