Programming IC2 24LC256
Results 1 to 13 of 13
    Oct 2003
    Australia
    Default Programming IC2 24LC256
    I'm trying to pre-program my IC2 eeprom using winpic800.
    Apparantly this program can program IC2 devices but there is no help info on the hardware setup.
    Has anyone done this before?
    Cheers
    Squib
    Aug 2005
    What programmer are you using with winpic.
    Sphere....
    Oct 2003
    Australia
    Looks like Winpic800 is a bit buggy... it works well using IC-prog -D... using my very simple 3 resistor programmer. :P
    Have a great day.
    Cheers
    Squib
    Aug 2005
    I have a jdm myself, but I have used a SN7407 to buffer the signals to eliminate programing errors. Glad to see you sorted your problem.
    Sphere...
    Yo Squib,
    Is there a link to more info on this? I've spent almost $300 on 3 different programmers.
    Just feel like kicking myself in the ___, for not knowing.
    Oct 2003
    Australia
    Quote Originally Posted by Darrel Taylor
    Yo Squib,
    DT, its kinda in my head, but based loosly on my simple programmer http://www.picbasic.co.uk/forum/showthread.php?t=703 the only difference is that VPP is not connected, so infact you only need two (2) resistors and a 5 volt supply.
    Here's a cut and paste from the top of my code.....
    ' TO PROGRAM THE 24LC256 MANUALLY USE ICPROG-D. SELECT THE AT24C256 CHIP
    ' CONNECT TO SERIAL PORT USING SIMPLE PROGRAMMER
    ' CONNECTIONS:
    ' PIN1:PIN4 TO GROUND
    ' PIN5 TO DATA (DTR via 4.7k) + (CTS)
    ' PIN6 TO CLOCK (RTS via 4.7k)
    ' PIN7 TO GROUND (FROM MAIN PCB AND SERIAL PORT GROUND)
    ' PIN8 TO VCC (FROM ext 5V)
    Cheers
    squib
    Oct 2003
    Australia
    Here's a funny one,
    I was hoping to use both an LCD (4bit mode) and the above mentioned eeprom on a 16F88 chip.
    Unfortunately, SDA is on Portb.1 and SCL is on Portb.4.
    I'm using RA2:RA4 for the LCD contol lines...
    How can I simultaneously hook up the LCD data lines and the I2C eeprom to the PIC? I've tried and it doesn't work.
    I'm thinking the only way is to go a bigger PIC with more I/O pins.
    Cheers Squib.
    Wow! Thanks Squib.
    That just might save me some time programming external EEPROMs for my boards. I've been doing it by writing a program for the PIC that it's attached to. Downloading the data to the EEPROM. Then loading the actual program that will run on the PIC. So I have to load 2 or three programs for each board.
    I'm feeling pretty dumb today. But tomorrow might be better.
    For the combo LCD/EEPROM, I can't think of a good way to do that. I think the LCD data might confuse the EEPROM. Just by chance, it might write something you don't want it to. Or worse, cause a short circuit condition since I2C is "open drain" and LCD data is "driven" high and low. But I can say that you aren't limited to the SDA/SCL pins of the PIC, unless you are using the hardware Synchronous Serial Port to interface with it. The I2CREAD/I2CWRITE in PBP can use any pin.
    Thanks again,
    &nbsp; Darrel
    Oct 2003
    Australia
    Hi DT,
    Well its good to know we can both learn something new, I never knew we could use any pin for I2C... that helps me out big time now. Thanks buddy.
    Cheers
    Squib
    Well maybe you just forgot, it have been discussed many times.
    I2CREAD,I2CWRITE, SERIN, SEROUT, etc etc, are software solution. AND allow you to use the pin you want. It's no coincidence why you can choose your favourite pin.
    HPWM, HSERIN, HSEROUT use the internal Hardware AND don't allow to choose specific pins (except for alternate CCP pin in HPWM)
    Mar 2006
    INDIA
    Default This is also simple 24lc programmer
    This is also simple 24lc programmer without extrnal power ,with icprog.
    That's a little more than 2 resistors. But it looks like it might be a little safer with the voltage clamping.
    Hmmm, self powered too.
    I think I'll try it.
    You could save few component by using the USB 5V. I already built this interface with USB power and used IC-PROG AND/OR PonyProg for the on-the-road radio decode service. Worked well before i did the decode dongle.
  1. Data Programming Error at 0000
    By cpatnoi in forum mel PIC BASIC Pro
    Last Post: - 22nd May 2009, 04:37
  2. Problems programming
    By Lionheart in forum General
    Last Post: - 7th December 2008, 17:51
  3. PIC programming algorithm - where is it to find?
    Last Post: - 24th June 2007, 19:31
  4. Some questions for programming
    By fnovau in forum mel PIC BASIC Pro
    Last Post: - 5th July 2006, 17:04
  5. MELab Programming
    By tarr in forum mel PIC BASIC Pro
    Last Post: - 22nd March 2006, 14:36
