16F88 - AD converter module always "ON"
Results 1 to 3 of 3
    SWITZERLAND (french speaking)
    Default 16F88 - AD converter module always "ON"
    Hi there,
    I'm trying to understand the AD converter module on my 16F88.
    For testing purposes, I have a LCD and a pot connected to the PIC and everything runs fine.
    The ADCON0 register controlls the AD module. Bit 0 (ADON) activates or shuts off the module (0=OFF / 1=ON).
    When I set this Bit to 0, I expect the AD converter module to be stopped. Operating the pot at that time will still show changing values on the display.
    I don't understand why.
    Roger
    Hi flotulopex,
    If you are using the ADCIN statement to get the A/D values, then it will turn the ADON bit back on each time you use it.
    If you were using the A/D registers manually, it would still be off.
    But if you really want the Pins to be digital, you should...
    ANSEL = 0
    CMCON = 7
    HTH,
    Thank you.
    I didn't know about the ADCIN exact operation.
    The Micro Code Studio's help file is a little to spartan to me...
    Roger
  1. Version Control
    Last Post: - 16th October 2011, 18:12
  2. Interfacing 16F88 to RF module
    By scomi85 in forum General
    Last Post: - 19th February 2009, 13:52
  3. AD works in Porta.0 but not in porta.1
    Last Post: - 19th February 2008, 21:22
  4. question regarding an external AD converter
    By dtoohey in forum mel PIC BASIC Pro
    Last Post: - 15th March 2005, 06:50
  5. ADC problem
    By NacNud in forum mel PIC BASIC Pro
    Last Post: - 15th December 2004, 03:27
