16F877A with 20MHz XTAL not working?
Results 1 to 13 of 13
    Default POWER to the PIC !
    Hi ustredna,
    What everyone here is trying to explain, but not quite doing is this:
    The PIC oscillator requires a bit more power to operate at speeds above 4mhz.
    you set the program parameters to be correct in your code for the oscillator speed with your DEFINE OSC 20 statement, but you tell the programmer to enable the oscillator to use the high power setting with the config fuse, or by manualy selecting HS on the programmer's software, elsewise your Oscillator is not going to work.
    JS
    Mar 2008
    Texas, USA
    Mar 2006
    INDIA
    you will have to edit your 16F877A.inc file as below.
    NOLIST
    ifdef PM_USED
    LIST
    include 'M16F87xA.INC' ; PM header
    device pic16F877A, HS_osc, wdt_OFF, lvp_off, protect_ON , CP_ON
    XALL
    NOLIST
    LIST
    LIST p = 16F877A, r = dec, w = -302
    INCLUDE "P16F877A.INC" ; MPASM Header
    __config _HS_OSC & _WDT_OFF & _LVP_OFF & _CP_OFF
    NOLIST
    LIST
    Your 16F877A will work on 20Mhz.
    Default My Opinion
    Quote Originally Posted by precision View Post
    NOLIST
    ifdef PM_USED
    LIST
    XALL
    NOLIST
    LIST
    NOLIST
    LIST
    Hi ustredna,
    The file mentioned above is included into your code automaticly when you compile using PBP and it contains "Default Settings" for your config statements, so if you do not include config statements in YOUR CODE it will default to the settings in this file. If you change the settings here it will DEFAULT to whatever you set here. Now for my opinion: I would not change the default to 20 mhz, I would instead simply put a semicolon at the beginning of the config statements so as to make the compiler overlook them as comments, and then include my own config statements in "MY CODE" every time.
    JS
    edit: Oh BTW, each PIC type has it's own file like this.
    Default My experience on this
    Ive the same problem, i thange the crystal, caps, code... and nothing (at 1st time when y bought it works on 20mhz).Then today i went to the store ans bougt one pic more, caps, clocks. The problem was on the the 1st pic!!! i was not very good only acepts 4mhz clocks.
    Feb 2011
    Kuantan, Pahang, Malaysia
    Default Re: 16F877A with 20MHz XTAL not working?
    NOLIST
    ifdef PM_USED
    LIST
    XALL
    NOLIST
    LIST
    NOLIST
    LIST
    thx, this one works.
  1. First time with external oscillator - 16F877a Not working
    Last Post: - 15th October 2009, 18:14
  2. 16F877a, stopped working
    By comwarrior in forum General
    Last Post: - 18th September 2009, 07:39
  3. 16F877 vs. 16F877A
    By DavyJones in forum General
    Last Post: - 11th April 2009, 19:22
  4. Pls How can I make 16F877A use 15MHz Xtal
    By ozzie1st in forum mel PIC BASIC Pro
    Last Post: - 27th July 2007, 00:01
  5. Clock connection to DS1802 from 16F877A
    By coyotegd in forum mel PIC BASIC Pro
    Last Post: - 3rd January 2006, 19:52
