array problem
Results 1 to 12 of 12
Thread: array problem
    OH! A competition.
    And as usual, I'm too late, oh well. Here's my entry.
    <font color="#008000"><b>DEFINE  </b></font><b>NO_CLRWDT 1                   </b><font color="#0000FF"><b><i>; Saves 2 words  :)
    </i></b></font><b>array </b><font color="#008000"><b>VAR WORD </b></font>[<b>5</b>] <b>BANK0 SYSTEM
    ArrayStart </b><font color="#008000"><b>CON </b></font><b>EXT
    </b><font color="#000080">@ArrayStart = array + 1               </font><font color="#0000FF"><b><i>; Start at highbyte of element 0
    </i></b></font><b>LastElement </b><font color="#008000"><b>CON </b></font><b>EXT
    </b><font color="#000080">@LastElement = ArrayStart + (4 * 2)   </font><font color="#0000FF"><b><i>; Stop at element 4
    </i></b></font><b>FSR </b>= <b>ArrayStart
    Loop1</b>:
        <font color="#008000"><b>IF </b></font><b>INDF </b>= <b>0 </b><font color="#008000"><b>THEN GOSUB </b></font><b>Compute
        FSR </b>= <b>FSR </b>+ <b>2
    </b><font color="#008000"><b>IF </b></font><b>FSR </b>&lt; <b>LastElement </b><font color="#008000"><b>THEN </b></font><b>Loop1
    </b><font color="#0000FF"><b><i>;----------------------------------
    </i></b></font><b>Compute</b>:
    <font color="#0000FF"><b><i>'Do something
    </i></b></font><font color="#008000"><b>RETURN</b></font>
    21 words<hr>
    Or going the ASM route
    <font color="#000000"><b>array </b><font color="#008000"><b>VAR WORD </b></font>[<b>5</b>] <b>BANK0 SYSTEM
    </b><font color="#008000"><b>ASM
    </b></font><font color="#000080">ArrayStart = array + 1               </font><font color="#0000FF"><b><i>; Start at highbyte of element 0
    </i></b></font><font color="#000080">LastElement = ArrayStart + (4 * 2)   </font><font color="#0000FF"><b><i>; Stop at element 4
        </i></b></font><font color="#000080">movlw    ArrayStart
        movwf    FSR                     </font><font color="#0000FF"><b><i>; FSR = ArrayStart
    </i></b></font><font color="#000080">Loop1
        movf     INDF, W
        btfsc    STATUS, Z
        call     _Compute                </font><font color="#0000FF"><b><i>; if INDF = 0 then gosub Compute
        </i></b></font><font color="#000080">movlw    2
        addwf    FSR, F                  </font><font color="#0000FF"><b><i>; FSR = FSR + 2
        </i></b></font><font color="#000080">movlw    LastElement
        subwf    FSR, W
        btfss    STATUS, C
        goto     Loop1                   </font><font color="#0000FF"><b><i>; if FSR &lt; LastElement then Loop1
    </i></b></font><font color="#008000"><b>ENDASM
    </b></font><font color="#0000FF"><b><i>;----------------------------------
    13 words
    Neat!
    I wasn't aware that we could access to FSR and INDF directly... thanks!
    i just hope our friend don't use 18Fs or some 12 bit core
    I had the same concerns, but after compiling the "Melanie idea for solution" example(post 9), I found that it was 35 words instead of bytes. So I knew he was using a 16F (or C).
    And yup, you can directly access any register with PBP. They are all defined in the PIC14EXT.BAS file in the PBP folder.
    Last Post: - 14th June 2016, 08:55
  2. Simple Array Demo
    By Archangel in forum Code Examples
    Last Post: - 15th February 2010, 05:46
  3. Problem with ASM IRQ using FSR0 on PIC18F252
    By mytekcontrols in forum mel PIC BASIC Pro
    Last Post: - 11th March 2008, 21:48
  4. Array problem (18F2550)
    By Ronald123 in forum mel PIC BASIC Pro
    Last Post: - 8th January 2008, 19:47
  5. Problem with bit array
    By Dick M in forum mel PIC BASIC Pro
    Last Post: - 12th May 2005, 18:03
