array problem
Results 1 to 12 of 12
Thread: array problem
    ro37bis's Avatar
    ro37bis Guest
    Angry array problem
    hello guys,
    I need to make some like this:
    array var word [5]
    C var byte
    for c = 0 to 5
    if array[C].highbyte = 0 then ' <- Compiler message: This style array syntax not supported
    gosub Compute
    next c
    Compute:
    'Do something
    but the compiler do not support my array style.
    Some idea to solve it?
    tnk in advance.
    Roberto from Italy
    Most things are already somewhere here on the forum... you just need to SEARCH for them...
    http://www.picbasic.co.uk/forum/showthread.php?t=544
    ro37bis's Avatar
    ro37bis Guest
    Thumbs up RE: Array problem
    Hi Melanie,
    usefull!!
    Tnk you very much!!!!!!!
    Roberto
    Jan 2006
    Istanbul
    Like this ?
    array var word [5]
    C var byte
    Temp Var word
    for c = 0 to 5
       Temp = array[C]
       if temp.highbyte = 0 then gosub Compute
    next c
    Or maybe
    array var word [5]
    C var byte
        for c = 0 to 5
            if (array[C]>>8) = 0 then gosub Compute
            next
    Compute:
        'Do something
    another method...
    array var word [5]
    C var byte
        for c = 0 to 5
            if array[C]<=$00FF then gosub Compute
            next
    Compute:
        'Do something
    May 2006
    Del Rio, TX, USA
    Roberto, Sayzer and Steve
    Me thinks you will avoid much trouble if the array has 6 elements, or the FOR...NEXT counts from 0 to 4.
    Steve B
    LMAO! ssshhhhhhut!
    Jan 2006
    Istanbul
    I know that Steve sleeps only a few hrs from late morning to later morning.
    Just like I do.
    Don't know about Roberto's.
    ro37bis's Avatar
    ro37bis Guest
    Smile thk you for the support
    Hi guys,
    thank you for the support.
    I tested all of your suggestion.
    the Sayzer solution require 34 bytes,
    the 1st Mister_e solution require 83 bytes,
    the 2nd solution require 66 bytes.
    the Melanie idea for solution:
    array var word [5]
    C var byte
    for c = 1 to 9 step 2
    if array.lowbyte(c) = 0 then gosub Compute
    next
    Compute:
    'Do something
    require 35 bytes.
    The winner is:......... Sayzer.
    bye
    Roberto
    OH! A competition.
    And as usual, I'm too late, oh well. Here's my entry.
    <font color="#008000"><b>DEFINE  </b></font><b>NO_CLRWDT 1                   </b><font color="#0000FF"><b><i>; Saves 2 words  :)
    </i></b></font><b>array </b><font color="#008000"><b>VAR WORD </b></font>[<b>5</b>] <b>BANK0 SYSTEM
    ArrayStart </b><font color="#008000"><b>CON </b></font><b>EXT
    </b><font color="#000080">@ArrayStart = array + 1               </font><font color="#0000FF"><b><i>; Start at highbyte of element 0
    </i></b></font><b>LastElement </b><font color="#008000"><b>CON </b></font><b>EXT
    </b><font color="#000080">@LastElement = ArrayStart + (4 * 2)   </font><font color="#0000FF"><b><i>; Stop at element 4
    </i></b></font><b>FSR </b>= <b>ArrayStart
    Loop1</b>:
        <font color="#008000"><b>IF </b></font><b>INDF </b>= <b>0 </b><font color="#008000"><b>THEN GOSUB </b></font><b>Compute
        FSR </b>= <b>FSR </b>+ <b>2
    </b><font color="#008000"><b>IF </b></font><b>FSR </b>&lt; <b>LastElement </b><font color="#008000"><b>THEN </b></font><b>Loop1
    </b><font color="#0000FF"><b><i>;----------------------------------
    </i></b></font><b>Compute</b>:
    <font color="#0000FF"><b><i>'Do something
    </i></b></font><font color="#008000"><b>RETURN</b></font>
    21 words<hr>
    Or going the ASM route
    <font color="#000000"><b>array </b><font color="#008000"><b>VAR WORD </b></font>[<b>5</b>] <b>BANK0 SYSTEM
    </b><font color="#008000"><b>ASM
    </b></font><font color="#000080">ArrayStart = array + 1               </font><font color="#0000FF"><b><i>; Start at highbyte of element 0
    </i></b></font><font color="#000080">LastElement = ArrayStart + (4 * 2)   </font><font color="#0000FF"><b><i>; Stop at element 4
        </i></b></font><font color="#000080">movlw    ArrayStart
        movwf    FSR                     </font><font color="#0000FF"><b><i>; FSR = ArrayStart
    </i></b></font><font color="#000080">Loop1
        movf     INDF, W
        btfsc    STATUS, Z
        call     _Compute                </font><font color="#0000FF"><b><i>; if INDF = 0 then gosub Compute
        </i></b></font><font color="#000080">movlw    2
        addwf    FSR, F                  </font><font color="#0000FF"><b><i>; FSR = FSR + 2
        </i></b></font><font color="#000080">movlw    LastElement
        subwf    FSR, W
        btfss    STATUS, C
        goto     Loop1                   </font><font color="#0000FF"><b><i>; if FSR &lt; LastElement then Loop1
    </i></b></font><font color="#008000"><b>ENDASM
    </b></font><font color="#0000FF"><b><i>;----------------------------------
    13 words
    Neat!
    I wasn't aware that we could access to FSR and INDF directly... thanks!
    i just hope our friend don't use 18Fs or some 12 bit core
    I had the same concerns, but after compiling the "Melanie idea for solution" example(post 9), I found that it was 35 words instead of bytes. So I knew he was using a 16F (or C).
    And yup, you can directly access any register with PBP. They are all defined in the PIC14EXT.BAS file in the PBP folder.
    <br>
    Last Post: - 14th June 2016, 08:55
  2. Simple Array Demo
    By Archangel in forum Code Examples
    Last Post: - 15th February 2010, 05:46
  3. Problem with ASM IRQ using FSR0 on PIC18F252
    By mytekcontrols in forum mel PIC BASIC Pro
    Last Post: - 11th March 2008, 21:48
  4. Array problem (18F2550)
    By Ronald123 in forum mel PIC BASIC Pro
    Last Post: - 8th January 2008, 19:47
  5. Problem with bit array
    By Dick M in forum mel PIC BASIC Pro
    Last Post: - 12th May 2005, 18:03
