ISD4004-16mp
Results 1 to 2 of 2
Thread: ISD4004-16mp
    donhuan's Avatar
    donhuan Guest
    Default ISD4004-16mp
    Hi Forum,
    Does anyone have some BASIC code to get me started
    communicating with ISD4004?
    Thank You
    TONIGALEA's Avatar
    TONIGALEA Guest
    ' Demonstration of the ISD1416 chipcorder device
    ' Speak any number from 0 to 65535
    ' Does not speak the leading zeroes and is capable of speaking the words
    ' 'POINT' and 'DEGREES' by using the 12 previously recorded messages
    ' The messages are also displayed on a serial LCD
    Include "Modedefs.Bas"
    ' ** Setup the Crystal Frequency, in mHz **
    Define OSC 4 ' Set Xtal Frequency
    ' ** Setup the Debug Defines **
    Define DEBUG_REG PortA ' Debug PortA
    Define DEBUG_BIT 0 ' *** Debug pin Bit-0 ***
    Define DEBUG_BAUD 9600 ' *** Debug Baud Rate ***
    Define DEBUG_MODE 1 ' Set Serial Mode 0=True, 1=Inverted
    Define DEBUG_PACING 300 ' Delay 'in Us' between characters sent
    ' ** Define LCD Constants **
    I Con 254 ' Control Byte
    Clr Con 1 ' Clear the display
    Line1 Con 128 ' Point to beginning of line 1
    Line2 Con 192 ' Point to beginning of line 2
    Line3 Con 148 ' Point to beginning of line 3
    Line4 Con 212 ' Point to beginning of line 4
    Cgram Con 64 ' Point to Cgram within LCD
    ' ** Assign the ISD1416 pins **
    STROBE Var PortA.1 ' End of message pulse
    PLAYE Var PortA.2 ' Pull low to play message, bring high to end
    PLAYL Var PortA.3 ' Pulse to play complete message
    ' ** Declare the Variables **
    Counter Var Word ' General purpose counter
    S_Digit Var Byte ' Build up the seperate digits, loop
    S_Num Var Word ' The number to say is loaded into here
    SN Var Word ' Used in the sayit subroutine
    ' ** Declare Constants **
    S_Point Con 131
    S_Degrees Con 144
    ' ** THE MAIN PROGRAM STARTS HERE **
    Debug I,Clr:Pause 30 ' Clear the LCD
    TrisB=0 ' Make PortB an output
    TrisA.3=1 ' Disconnect the PLAYE line
    Again: For Counter=0 to 99 ' Count up to 100
    S_Num=Counter ' Place the counter into S_NUM
    Debug I,Line1,dec2 S_Num,"."
    Gosub Sayit ' Say the number held in S_NUM
    Gosub Say_Point ' Say the word 'POINT'
    Another:
    Random S_Num
    If S_Num> 99 then Another
    Debug I,Line1+3,#S_Num," Degrees "
    Gosub Sayit
    Gosub Say_Degrees
    Pause 300 ' Pause after the number is spoken
    Next
    Goto Again
    Sayit: For S_Digit=4 to 0 step-1 ' Loop for 5 digits (0-65535)
    SN=S_Num dig S_Digit ' Extract the seperate digits
    If S_Num<10 and S_Digit>0 then Over ' Zero supression for 0-10
    If S_Num<100 and S_Digit>1 then Over ' Zero supression for 10-100
    If S_Num<1000 and S_Digit>2 then Over ' Zero supression for 100-1000
    If S_Num<10000 and S_Digit>3 then Over ' Zero supression for 1000-10000
    Lookup SN,[0,14,27,40,53,66,79,92,105,118],SN ' Find the address of the message
    PortB=SN ' Place it on the ISD's address line
    Gosub Play ' Say the number
    Over: Next ' Close the loop
    ' ** Say the word 'POINT' **
    Say_Point:
    PortB=S_Point
    Gosub Play
    ' ** Say the word 'DEGREES' **
    Say_Degrees:
    PortB=S_Degrees
    Gosub Play
    Play:
    Pause 50 ' Give the ISD time to process its address lines
    High PLAYL ' Bring the PLAYL line high initially
    @ Nop ' Wait 1us at 4mHz
    Low PLAYL ' Bring the PLAYL line low to trigger the ISD chip
    While STROBE=1:Wend ' Wait for the message to finish
    ' By polling for the low pulse from the REC_LED
    ' pin of the ISD1416
  1. isd4004 help "urgent"
    By mohamad_shahata in forum mel PIC BASIC Pro
    Last Post: - 2nd April 2008, 12:47
