hi,
I had the same problem.
Try to check B0 insted of the seperated Bits.
Diggi
hi,
Diggi
MIIIIP bad answer. If you have a MAX232 between your PIC and your PC you must use the True mode in SEROUT
SerOut 2, T2400, ("a")
psst there is nothing french in the character you see.. trust me
Ca c'est du francais stie!
I solved the problem I donīt know how but itīs working now.....Here is one of the signs I received before: ā or € etc....
thx
Martin
