How to go to sleep
Results 1 to 10 of 10
    Jun 2006
    I change the code but i don't know if it is correct
                 DEFINE LCD_DREG	PORTB
    	DEFINE LCD_DBIT 0
    	DEFINE LCD_RSREG PORTA
    	DEFINE LCD_RSBIT 2
    	DEFINE LCD_EREG	PORTA
    	DEFINE LCD_EBIT 3
    	DEFINE LCD_BITS 4
    	DEFINE LCD_LINES 2
    	DEFINE I2C_SCLOUT 1
    	SCL var PORTA.1
    	SDA	var	PORTA.0
    	UP	    var	PORTB.6
    	DOWN	var	PORTB.7
    	CH_PAS	var	PORTB.5
    	Input	UP
    	Input	DOWN
    	Input	CH_PAS
        b1	var Byte
        b2	var Byte
        b3	var Byte
        b5	var	Byte
        F1	var	Word
        F2	var	Word
        F3	var	Word
        ADDR1   VAR	Byte
        ADDR2	VAR	Byte
    	LOCK	VAR	Byte
    	TMP	    VAR	Word
    	TMP_LO	VAR	TMP.LowByte
    	TMP_HI	VAR	TMP.HighByte
    	PLLBASE	VAR	Word
    	PLL	    VAR	Word
    	LO	    VAR	PLL.LowByte
    	HI	    VAR	PLL.HighByte
    	PAS	    VAR	Byte
                 ' Initialize interrupts
                 On Interrupt Goto  loop
                 INTCON = $88                   ' enable interrupts on RB4 through RB7
    MAIN:
    	PLL = PLLBASE + TMP
    	I2CWRITE SDA,SCL,ADDR1,[HI,LO,$8E]	  'Sending of the data to the module
       	GoSub CALCUL		'calculate the frequency for posting
        GoSub AFFICHAGE     'post the frequency
       	PAUSE 200
        @SLEEP
     loop:
             Button UP,1,10,2,b1,1,MONTE
    		Button DOWN,1,10,2,b2,1,DESCEND
    		Button CH_PAS,1,255,0,b3,1,	CHOIX
    		PAUSE 100
      	    I2CREAD SDA,SCL,ADDR2,[LOCK]
             GoSub AFFICHAGE
            INTCON.1 = 0                        ' clear the interrupt flag
            Resume                              ' end of interrupt service routine
            Enable                              ' allow interrupts again
            GoTo loop
    MONTE:
            GoTo MAIN
    DESCEND:
            GoTo MAIN
    CHOIX:
            GoTo MAIN
    Jun 2006
    BUTTON Pin,Down,Delay,Rate,BVar,Action,Label
    Because the 'down' in my code is 1 the pic go to interrupt continues (loop)
    How to change the code (not the button);
    I've used something like this in the past & it worked fine:
    START:
    IF PORTA.1 = 0 THEN WORK 'BUTTON PUSHED
    PAUSE 100
    LET X = X + 1
    IF X > 250 THEN RELAX 'SHUT DOWN AFTER 25 SEC
    GOTO START
    WORK:
    DO WHATEVER
    LET X = 0
    GOTO START
    RELAX:
    NAP 0
    IF PORTA.1 = 1 THEN RELAX
    LET X = 0
    GOTO START
    Jun 2006
    I don't know if the
    is right
    Jun 2006
    some one to help me;
    Jul 2005
    INTCON=$88 looks good to me. You've got the interupts enabled, and Port B change enables also.
    Keeping in mind I've not done interupts in PBP (raw assembler yeah) I'd put the button handeling code inside the interupt handler. However, this would be a problem with the BUTTON command as that wants to be inside a loop, so maybe wake up for a while every time you see a keychange.
    Jun 2006
    Quote Originally Posted by ErnieM
    However, this would be a problem with the BUTTON command as that wants to be inside a loop.
    Maybe this is the my problem and i don't know how to solve.
  1. Won't go back to SLEEP after 1st Interrupt
    Last Post: - 29th June 2009, 09:00
  2. Battery powered applications
    Last Post: - 22nd June 2009, 07:12
  3. 16F628A current high during sleep
    Last Post: - 9th October 2006, 10:21
  4. Wierd sleep issue
    By orca in forum mel PIC BASIC Pro
    Last Post: - 14th March 2006, 22:06
  5. SLEEP Command and Interupts 16F648A
    By ghoot in forum mel PIC BASIC Pro
    Last Post: - 28th May 2004, 18:35
