18f4620 Configuration bits
Results 1 to 3 of 3
    Sep 2006
    Mexico
    Default 18f4620 Configuration bits
    Hello, i cant use the directive @ CONFIG. I have modified the .inc file as follow:
    ;* 18F4620.INC *
    ;* By : Leonard Zerman, Jeff Schmoyer *
    ;* Notice : Copyright (c) 2004 microEngineering Labs, Inc. *
    ;* All Rights Reserved *
    ;* Date : 12/14/04 *
    ;* Version : 2.46 *
    ;* Notes : *
    NOLIST
    ifdef PM_USED
    LIST
    "Error: PM does not support this device. Use MPASM."
    NOLIST
    LIST
    LIST p = 18F4620, r = dec, w = -311, f = inhx32
    INCLUDE "P18F4620.INC" ; MPASM Header
    ;__CONFIG _CONFIG1H, _OSC_XT_1H
    ;__CONFIG _CONFIG2H, _WDT_ON_2H & _WDTPS_128_2H
    ;__CONFIG _CONFIG3H, _PBADEN_OFF_3H
    ;__CONFIG _CONFIG4L, _LVP_OFF_4L & _XINST_OFF_4L
    NOLIST
    LIST
    EEPROM_START EQU 0F00000h
    BLOCK_SIZE EQU 8
    What can i do to solve this problem? The mcs error is: Error[116] Address label duplicated or diferent in second pass (_4loop).
    Here is my code:
    @ config osc=HSPLL
    DEFINE HSER_BAUD 4800
    DEFINE ADC_BITS 8
    DEFINE ADC_CLOCK 3
    DEFINE ADC_SAMPLEUS 10
    CMCON=$07
    ADCON1=%00001100
    TRISA=%00000100
    TRISB=0
    b0 var byte
    loop:
    ADCIN 2,b0
    pause 4000
    Hserout [dec b0,13, 10]
    goto loop
    It works fine if i comment the first config line and modify configuration bits in mplab before programming the pic.
    blainecf's Avatar
    blainecf Guest
    Default include is being included included
    include is being included twice. this happens if you explicitly include a file that's automatically being included already. try commenting out your include statement until the error message goes away.
    bcf
    Sep 2006
    Mexico
    Quote Originally Posted by blainecf
    bcf
    But i doesnt use include in my code. What can i do?
    Last Post: - 14th June 2016, 08:55
  2. Configuration bits and timing
    By Christos_K in forum mel PIC BASIC Pro
    Last Post: - 17th November 2012, 09:53
  3. Configuration bits in a HEX file gone missing?
    By grzes.r in forum mel PIC BASIC Pro
    Last Post: - 2nd February 2010, 02:10
  4. Configuration bits
    By Armando Herjim in forum General
    Last Post: - 5th December 2006, 17:51
  5. error on compiling
    By parker in forum mel PIC BASIC Pro
    Last Post: - 16th June 2005, 15:31
