ADC Channels
Results 1 to 6 of 6
Thread: ADC Channels
    Post ..
    Well thanks both of you. The pic I use is 18F4550. Iīm going to try out your advices, but there is still one thing Iīd like to know. If I need 8 bit resolution I have to use left justified, (thanks for that!) so, where will I find the data? Will it be stored in adresL or in adresH... and, if I decided to use 10 bit resolution, which bits would be sored is adresL and which bits in adresH? I think my questions are pretty clear but if I didnīt explain myself please let me know and thank you again.
    Regards.
    Oh, I forgot! I need to read a signal that goes 0-5 volts... how do you think I should use the Vref+ and the Vref-??? Thank you!!
    Armando H.
    Jul 2005
    ADRESHI has the most signifigant bits, leaving ADRESLO with the least signifigant bits.
    The data from the A2D is 10 bits wide... so the question is where to put 10 bits into 2 seperate 8 bit result registers.
    If you left justify, you space everthing so the highest (most sig) data bit align with the highest (most sig) register bit.
    Right justify puts the lowest data bit in line with the register's lowest bit. That means the hi register only has the top 2 sig bits.
    When you left justify, as the hi register has the most sig 8 bits it also has the 8-bit (non rounded) result.
    Hope this is more helpful then confusing.
    Iran
    you don't need to use 10 bit A/D. you can use 8 bit , that is easier than 10 bit.
    like this:
    define OSC 4
    TRISA = %11111111
    x var byte
    ADCON1 = %00000010
    adcin 0,x ' 0is the channel number and x is the variable
    you don't need to connect the Vref+ and Vref- to somewher.
    if you want to use 10 bit ask me again yo tell you.
  1. Stable Adc Reading Routine
    By gebillpap in forum General
    Last Post: - 13th May 2015, 03:18
  2. Can't get ADC to loop
    By TravisM in forum mel PIC BASIC
    Last Post: - 11th October 2009, 16:33
  3. ADC - 2 channels but not same voltage reference - how to?
    Last Post: - 25th November 2007, 20:03
  4. 12F675 ADC 'Issues'
    By harrisondp in forum mel PIC BASIC Pro
    Last Post: - 31st March 2005, 02:55
  5. Reading multiple ADC channels FAST
    By lwindridge in forum mel PIC BASIC Pro
    Last Post: - 21st April 2004, 23:37
