Pic Burner...
Results 1 to 4 of 4
Thread: Pic Burner...
    Cool Pic Burner...
    i want to build a PIC BURNER for my project.
    can some one recommend me a PIC BURNER that able to support many version of PIC manufacture by Microchip?
    malc-c's Avatar
    malc-c Guest
    Google or Yahoo for "JDM Programmer" - its simple to make, works well and if you use WinPICpro supports loads of chips
    SWITZERLAND (french speaking)
    Default Microchip AN589 Programmer
    Hello,
    I'm a newbie to PICs but I had this problem to find a good and reliable PIC programmer too.
    I built the JDM programmer an some derivates. It was okay until I used it on my laptop. It started with some problems.
    But the one I had the less trouble (in fact, I haven't had any up to now) is the AN589 from Microchip (see attachment - PDF file). This programmer is connected to the parallel port and can program almost any PICs. The only modification I had to make is to add 2 capacitors as you can see on the second attachment (JPG file).
    The programming software I use is ICProg (www.ic-prog.com).
    According to what I could find and read, serial programmers are good. Parallel ones are better since you must have an additional power supply and so, you make absolutely sure the Vpp (programming voltage on PIC) is correctly provided.
    This is my personal experience.
    Roger
  1. SMS via pic
    By kenandere in forum GSM
    Last Post: - 10th March 2010, 10:00
  2. HSERIN & Interupts (aka controlling PIC programs from a remote PC)
    Last Post: - 17th June 2009, 14:46
  3. pic to pic ir link versus wired link : help please anyone
    Last Post: - 30th May 2008, 21:01
  4. CD/DVD burner controlled by PIC - Possible?
    Last Post: - 7th August 2007, 08:09
    Last Post: - 11th March 2005, 23:14
