Pic - reset
Results 1 to 10 of 10
Thread: Pic - reset
    Apr 2004
    Hi guys,
    Sorry for the late reply but here is the code:
    @ DEVICE pic16F876A, HS_OSC
    ' System Clock Options
    @ DEVICE pic16F876A, WDT_OFF
    ' Watchdog Timer
    @ DEVICE pic16F876A, PWRT_ON
    ' Power-On Timer
    @ DEVICE pic16F876A, BOD_ON
    ' Brown-Out Detect
    @ DEVICE pic16F876A, LVP_OFF
    ' Low-Voltage Programming
    @ DEVICE pic16F876A, CPD_OFF
    ' Data Memory Code Protect
    ' Set to CPD_OFF for Development Copy
    ' Set to CPD_ON for Release Copy
    @ DEVICE pic16F876A, PROTECT_OFF
    ' Program Code Protection
    ' Set to PROTECT_OFF for Development Copy
    ' Set to PROTECT_ON for Release Copy
    ' Initial data for eeprom
    DEFINE OSC 10
    DEFINE I2C_SLOW 1
    DEFINE HSER_RCSTA 90h ' enable serial port, enable continuous receive
    define HSER_TXSTA 24h ' enable transmit, BRGH=1
    define HSER_SPBRG 64 ' set baudrate to 9600
    DEFINE HSER_CLROERR 1 ' automatic clear overrun error
    SYNC con $AA ' Synchronisation byte 10101010 binary
    RxD var PORTC.7 ' Rx data pin
    RxTx var PORTC.5 ' Rx / Tx function
    TxD var PORTC.6 ' Tx data pin
    Blue var PORTA.0 ' Blue led
    Red var PORTA.1 ' Red led
    MyAddress var byte
    Destination var byte
    Source var byte
    Data_1 var byte
    Temp var byte
    RCIF VAR PIR1.5
    TXIF VAR PIR1.4
    init: ADCON1=$07
    TRISB=%00000000
    PORTB=%00000000
    Low RxTx ' Set to receive mode RS485
    high Blue
    For temp = 0 to 10 high red
    pause 150
    low red
    pause 350
    Next temp
    low Blue
    MyAddress = 200 ' init complete
    loop: if RCIF then ' incomming data?
    hserin [wait(SYNC),Destination,Source,Data_1]
    high blue
    if Destination <> MyAddress Then loop ' verify address
    select case Data_1
    case 1
    gosub UnitOff
    case 2
    gosub UnitOn
    end select
    goto loop
    UnitOff:
    Low blue
    UnitOn:
    High blue
    strange, i'll bet on a hardware problem.... rrreeeaaalllyyy ssslllooowww start-up PSU maybe. BTW, do you have a complete schematic? if so, post it here.
    Try adding a 10K pull-up resistor on the RX pin...
  1. Pic reset and following lock up problem
    By zerosvarka in forum General
    Last Post: - 17th June 2009, 21:03
  2. pic reset sometimes
    By Pedro Pinto in forum mel PIC BASIC Pro
    Last Post: - 23rd January 2008, 18:27
  3. How to reset the pic by software ?
    By Shamir in forum mel PIC BASIC Pro
    Last Post: - 18th October 2006, 17:43
  4. Must reset PIC to get correct operation?
    Last Post: - 2nd June 2006, 02:59
  5. PIC problem, ways to do reset
    By lab310 in forum mel PIC BASIC Pro
    Last Post: - 26th May 2005, 15:31
