power adapter for k149d?
Results 1 to 3 of 3
    greenagain's Avatar
    greenagain Guest
    Default power adapter for k149d?
    Hey all,
    I've got some pics and a k149d programmer kit from kitsrus, and I'm trying to start experimenting with it. I'm hung up on a bit of a noob rock, however: I don't know what power adapter I should use with this thing. A 16vdc power adapter is required for the programmer, so I ordered this one:
    http://www.hvwtech.com/products_view.asp?ProductID=435
    Well, apparently, (sigh) I got the wrong one because it won't plug into the programmer. Could somebody help a noob out here by suggesting a power adapter that will work with this programmer?
    much thanks
    if it's just the plug that cause the problem... you could
    1. change the plug of the transformer
    OR
    2. change the plug of your programmer
    OR
    3.Solder directly the transformer wires to the programmer PCB
    in all cases be carefull to not revert the + and -
    greenagain's Avatar
    greenagain Guest
    Thanks for the response
    Yes, that's right. The plug does seem to be the problem. The thing is: I don't know what plug I should use. It wants 16vdc, so I got that. When it didn't fit, I said, well that's fine, I'll just find one that does fit. Looking at the stores online, 2.1mm for the center pin and 5.5mm for the outer cylinder seems to be the standard for 16vdc power adapters. So I just don't know what size I'm supposed to be looking for.
    Incidentally, I'm not really sure if it's too small or too big! It looks like it should fit, but it just doesn't!
    Thanks again!
  1. Won't go back to SLEEP after 1st Interrupt
    Last Post: - 29th June 2009, 10:00
  2. Battery powered applications
    Last Post: - 22nd June 2009, 08:12
  3. Pic getting part power from Analog Port
    By ShaneMichael in forum mel PIC BASIC Pro
    Last Post: - 22nd April 2009, 11:34
  4. PIC power backup with "super capacitor"
    Last Post: - 25th January 2007, 00:51
  5. 12 Servo's together does not seem to work, Power problem
    By macx75 in forum mel PIC BASIC Pro
    Last Post: - 13th December 2006, 20:30
