I have a problem with read from internal eprom
Results 1 to 9 of 9
    Jan 2006
    Istanbul
    Quote Originally Posted by don_mathew
    its not working but this
    b = $AA
    PORTB = b
    is working...
    so what can i do to get this way working
    READ 0,b
    PORTB = B.......
    Once you store initial values into your eeprom then
    you can also do this:
    READ 0, PORTB
    don_mathew's Avatar
    don_mathew Guest
    reading from eprom is working but when i try to read 15address location and save them one by one in array its not working...this example is not working can enybody tell me what is wrong in this code...on PIC simulator IDE v6.34 on
    var led[15] led board gives me sign on PORTB $0F instead $FF
    define OSC 8
    TRISB = $00
    PORTB = $00
    i var byte
    led var byte [15]
    led[0] = %00000001
    led[1] = %00000010
    led[2] = %00000100
    led[3] = %00001000
    led[4] = %00010000
    led[5] = %00100000
    led[6] = %01000000
    led[7] = %10000000
    led[8] = %10000001
    led[9] = %10000010
    led[10] = %10000100
    led[11] = %10001000
    led[12] = %10010000
    led[13] = %10100000
    led[14] = %11000000
    led[15] = %11111111
    loop:
    for i = 0 to 15
    PORTB = led[i]
    Next i
    goto loop
    PIC16F84A
    don_mathew's Avatar
    don_mathew Guest
    i found the problem...
    i'm c++ programmer and when u define array like this
    int var[15]
    that means var from 0 to 15 and thats 16 memory addresses
    and in pic basic
    led var byte [15] means from 0 to 14...i hope that this post will help someone...
    Jul 2005
    led var byte [15]
    That's your problem, you defined a 15 byte array and are trying to address the 16th element.
    led var byte [15] ' defines a 15 byte array addressed 0 to 14
    Change the 15 to a 16 and all should work.
    If you define a 16 byte variable, is it the same thing as defining a word variable?
    NOPE
    16 BITS will be a WORD.
  1. Cleaning up code
    Last Post: - 2nd December 2009, 08:14
  2. write -read problem?
    By turkuaz in forum mel PIC BASIC Pro
    Last Post: - 30th August 2009, 14:06
  3. SEROUT WORD variable problem
    Last Post: - 19th April 2009, 12:20
  4. Problem to read a PCF 8574
    By Darklakebridge7 in forum mel PIC BASIC Pro
    Last Post: - 26th February 2007, 22:56
  5. Changing declared variables names on the fly
    Last Post: - 16th December 2006, 07:34
