Hi DiGGi,
It usually depends on what's in the data sheet for the particular PIC you are using. These are something like: ADCON1 = 7 to disable the analog inputs and make the pins digital and CMCON = 7 to disable the comparators. There is a section in the PIC datasheet for each of these 2 items. Go to www.microchip.com and in the search field enter the part number you want a manual for. example: PIC16F628. This will give you selections on all the available documents for that part.
ADCON1 and CMCON are then placed in your initialization section of your program.
Please bear in mind that PICs that have analog ports don't necessarily have comparators. This is why you need to have the datasheet handy to refer to.
BobK
