PortA , PortB
Results 1 to 18 of 18
Thread: PortA , PortB
    DiGGi's Avatar
    DiGGi Guest
    Unhappy PortA , PortB
    Hello,
    I have a problem. I'm using PIC16F627A and PicBasic-Compiler (NOT PRO!!).
    If I use e.g. the commands 'PINx' , 'Button' or 'High/Low' they all work only on PortB. Is there a possibility that they work on PortA ??
    Dirk
    Mentor, Ohio
    Smile
    Hi DiGG,
    Did you remember to disable the analog and comparator features on PortA?
    BobK
    DiGGi's Avatar
    DiGGi Guest
    How can i disable them?
    Mentor, Ohio
    Smile
    Hi DiGGi,
    It usually depends on what's in the data sheet for the particular PIC you are using. These are something like: ADCON1 = 7 to disable the analog inputs and make the pins digital and CMCON = 7 to disable the comparators. There is a section in the PIC datasheet for each of these 2 items. Go to www.microchip.com and in the search field enter the part number you want a manual for. example: PIC16F628. This will give you selections on all the available documents for that part.
    ADCON1 and CMCON are then placed in your initialization section of your program.
    Please bear in mind that PICs that have analog ports don't necessarily have comparators. This is why you need to have the datasheet handy to refer to.
    BobK
    DiGGi's Avatar
    DiGGi Guest
    fiorst ThX for your help, but in my data sheet there is no ADCON1 and CMCON.
    is there an other solution , for PIC16F627A?
    Diggi
    Ok i do a try, PicBasic is far different from PBP...
    try
    POKE $1F,7 ' disable comparator
    refer to figure 4-2 of the datasheet for the memory map, and section 10 for the comparator module
    About 'Pin' Statement... i guess it's valid but i can't confirm how and why... time for me to purchase PBC. I hate to guess..
    Feb 2003
    Salt Lake City, Utah USA
    Smile
    Quote Originally Posted by DiGGi
    ...If I use e.g. the commands 'PINx' , 'Button' or 'High/Low' they all work only on PortB. Is there a possibility that they work on PortA ??
    No - As I remember, PBC does not have predefined pins or directions for PORTA. You must do them directly (make sure you turn off any analog presets as Bob has noted – this requirement is PIC specific).
    For example to make RA0 high,
    poke $85, %00000000	' make all PORTA outputs
    poke $05, %00000001	' set RA0 high
    to turn off RA0 and turn on RA1, you could then do this
    poke $05, %00000010
    Ask if you need more and good luck
    Paul Borgmeier
    Salt Lake City, UT
    USA
    __________________
  1. PICs can do more if use others than delays instructions
    By hardcore in forum mel PIC BASIC Pro
    Last Post: - 24th February 2010, 20:52
  2. 16F628A - Stops if release power switch.
    By dene12 in forum General
    Last Post: - 14th February 2009, 08:57
  3. shifting problem
    By helmut in forum mel PIC BASIC Pro
    Last Post: - 31st August 2007, 07:11
  4. Output PIC module
    By freelancebee in forum mel PIC BASIC Pro
    Last Post: - 12th September 2005, 21:10
  5. Can anyone help a beginner in a struggle?
    By douglasjam in forum mel PIC BASIC
    Last Post: - 6th May 2005, 00:29
