PortA , PortB
Results 1 to 18 of 18
Thread: PortA , PortB
    DiGGi's Avatar
    DiGGi Guest
    Unhappy PortA , PortB
    Hello,
    I have a problem. I'm using PIC16F627A and PicBasic-Compiler (NOT PRO!!).
    If I use e.g. the commands 'PINx' , 'Button' or 'High/Low' they all work only on PortB. Is there a possibility that they work on PortA ??
    Dirk
    Mentor, Ohio
    Smile
    Hi DiGG,
    Did you remember to disable the analog and comparator features on PortA?
    BobK
    DiGGi's Avatar
    DiGGi Guest
    How can i disable them?
    Mentor, Ohio
    Smile
    Hi DiGGi,
    It usually depends on what's in the data sheet for the particular PIC you are using. These are something like: ADCON1 = 7 to disable the analog inputs and make the pins digital and CMCON = 7 to disable the comparators. There is a section in the PIC datasheet for each of these 2 items. Go to www.microchip.com and in the search field enter the part number you want a manual for. example: PIC16F628. This will give you selections on all the available documents for that part.
    ADCON1 and CMCON are then placed in your initialization section of your program.
    Please bear in mind that PICs that have analog ports don't necessarily have comparators. This is why you need to have the datasheet handy to refer to.
    BobK
    DiGGi's Avatar
    DiGGi Guest
    fiorst ThX for your help, but in my data sheet there is no ADCON1 and CMCON.
    is there an other solution , for PIC16F627A?
    Diggi
    Feb 2003
    Salt Lake City, Utah USA
    Smile
    Quote Originally Posted by DiGGi
    ...If I use e.g. the commands 'PINx' , 'Button' or 'High/Low' they all work only on PortB. Is there a possibility that they work on PortA ??
    No - As I remember, PBC does not have predefined pins or directions for PORTA. You must do them directly (make sure you turn off any analog presets as Bob has noted – this requirement is PIC specific).
    For example to make RA0 high,
    poke $85, %00000000	' make all PORTA outputs
    poke $05, %00000001	' set RA0 high
    to turn off RA0 and turn on RA1, you could then do this
    poke $05, %00000010
    Ask if you need more and good luck
    Paul Borgmeier
    Salt Lake City, UT
    USA
    __________________
    Ok i do a try, PicBasic is far different from PBP...
    try
    POKE $1F,7 ' disable comparator
    refer to figure 4-2 of the datasheet for the memory map, and section 10 for the comparator module
    About 'Pin' Statement... i guess it's valid but i can't confirm how and why... time for me to purchase PBC. I hate to guess..
    DiGGi's Avatar
    DiGGi Guest
    hi
    Thank you both.
    @paul borgmeier, yes i know but i want to read the pin states seperately
    @mister_e the command you sent is working in PB but how can i controle the Pins on PortA with comands like Button/Pin ?
    Dirk
    Feb 2003
    Smile
    Quote Originally Posted by mister_e
    Hi Steve,
    No need to buy PBC or guess - the manual is free online on MELABs site.
    http://www.melabs.com/resources/index.htm#Manuals
    Paul Borgmeier
    Salt Lake City, UT
    USA
    __________________
    Feb 2003
    Smile
    Not tried but should work
    poke $85, $04	' make RA2 an input
    peek $05, B0	' read all of PORTA
    B0=B0 & $04	' isolate bit 2
    IF B0 = 0 then TurnOFF
    do something here if B0 = 1
    goto IFEXIT
    TurnOFF:
    do something  here if B0 = 0
    IFEXIT:
    Paul Borgmeier
    Salt Lake City, UT
    USA
    __________________
    DiGGi's Avatar
    DiGGi Guest
    hi
    The text in '2.2. The Pins' chapter says that PIN, Button - Commands only work on PortB. That is annoying.
    If I would use PEEK the stats of every pin would be written in a var.
    E.G. Pin 4 and Pin 6 are high , tha var would look like %01010000.
    Is that right?
    Feb 2003
    Smile
    Is that right?
    Yes - BITWISE operate to find what you want. See the LET command for more in the PBC manual and my example above your last post.
    Paul Borgmeier
    Salt Lake City, UT
    USA
    __________________
    DiGGi's Avatar
    DiGGi Guest
    Thanks a lot @ all
    I'll try this suggestion and i'll let you know the result.
    Dirk
    Edit: nevermind... too late
    Mentor, Ohio
    Smile
    Hi DiGGi,
    What has been said to you in the last few replies has been correct. If you want to get real basic here you can read porta like this:
    Peek PortA, B0 Read PortA and put results in Variable B0
    If Bit0 = 1 then task 1 'Reads PortA pin 0, if 1 then goto task 1
    If Bit1 = 1 then task 2 'Reads PortA pin 1, if 1 then goto task 2
    If Bit2 = 0 then task 3 'Reads PortA pin 2, if 1 then goto task 3
    This is really the basic way I started. You can do the BITWISE operations like Paul was showing you also. Whatever you are comfortable with.
    Variable B0 now represents a reading of the pins on PortA. you can now look at each pin individually.
    Do you have a copy of the PBC manual? If not goto www.melabs.com and download a copy. There is a 2 page explanation on PEEK and a small explanation of POKE.
    BobK
    DiGGi's Avatar
    DiGGi Guest
    thx
    i read that manual allready. And found the Bitx command. But i haven't time to test it yet. I'll tiy it later. And let you know if it works or not.
    Dirk
    Feb 2003
    Smile
    Quote Originally Posted by BobK
    ...If you want to get real basic here you can read porta like this:
    Bob,
    Nice addition - your approach is certainly easier and faster to write. Utilizing the fact that Bit0, Bit1, etc. are predifeined as the bits of B0 is the better approach for straightforward (i.e., normal) operations. Thanks for adding - now Dirk has lots of options. If it were me, I would skip the bitwise stuff and use what Bob has above.
    Paul Borgmeier
    Salt Lake City, UT
    USA
    __________________
    DiGGi's Avatar
    DiGGi Guest
    Default workin
    hi,
    my prog i working by using Peek and Bit0, Bit1 ...
    Thanks for your help!
    Diggi
  1. PICs can do more if use others than delays instructions
    By hardcore in forum mel PIC BASIC Pro
    Last Post: - 24th February 2010, 19:52
  2. 16F628A - Stops if release power switch.
    By dene12 in forum General
    Last Post: - 14th February 2009, 07:57
  3. shifting problem
    By helmut in forum mel PIC BASIC Pro
    Last Post: - 31st August 2007, 06:11
  4. Output PIC module
    By freelancebee in forum mel PIC BASIC Pro
    Last Post: - 12th September 2005, 20:10
  5. Can anyone help a beginner in a struggle?
    By douglasjam in forum mel PIC BASIC
    Last Post: - 5th May 2005, 23:29
