Delta-Sigma-ADC in Assembler embedded in PBP, increasing resolution
Results 1 to 15 of 15
    Post
    These lines checks for 1024 passes through the loop and stops if reached.
    andlw 0x04 ; Are we done? (We're done when bit2 of
    btfsc STATUS,Z ; the high order byte overflows to 1).
    All you need to do is change ....
    andlw 0x04
    ..... to .......
    andlw 0x02 for 512(9 bits)
    andlw 0x08 for 2048(11 bits)
    andlw 0x10 for 4096(12 bits)
    andlw 0x20 for 8192(13 bits)
    andlw 0x40 for 16384(14 bits)
    andlw 0x80 for 32768(15 bits)
    If you need better resolution it can be done, but needs more changing in the code.
    /Ingvar
    In a world of german electrons
    Thank you so far.
    In my current application, I need around 750 steps. Surely I could use 1024 steps right now.
    I want to change it to the number of steps wanted, but I have not understood the relation yet.
    Please explain the math behind your examples.
    Post
    The code checks if bit 2 of the high byte of the wordsized variable "counter" is set. If it is, the program has looped around 1024 times, if not it keeps looping.
    There is really no math involved, 1024dec = 0400hex = 0000010000000000bin.
    You don't want to check for anything more complicated than if a single bit is being set or cleared. That would slow the ADconversion down, not something you want to do. I'm not saying it can't be done, just that it wouldn't be very easy. Especially if you don't know assembler and i get the impression that you don't.
    My advice is that you stick with 10 bits(1024) and when the conversion is complete you scale the result to your desired value. That can be done in various ways. Here's a few..... all will scale to 752.
    Dummy = ADresult * 752
    ScaledResult DIV32 1024
    ScaledResult = ADresult */ 188 '752/1024*256=188
    ScaledResult = ADresult ** 48128 '752/1024*65536=48128
    /Ingvar
    What about using
    andlw 0x2F0 ; Are we done? (We're done when bit2 of
    Question
    No, you can only check one byte(8bits) in one go. You're also trying to check several bits at the same time, only one is "allowed". If you really MUST check for something more complicated you'll need to rewrite the code yourself. Certanly possible but nothing i will help you with.
    Good luck.
    /Ingvar
    PS. Is there a perticular reason why you can't use 10 bits and scale the result as i showed you in my last post? DS.
    Where is the result stored - in result_l or result_h or are they the same ?
    At U = Umax there should be a value of 1024.
    Post
    Result_h is the high byte(8bits) of the wordsized(16bits) result. Result_l holds the lower 8 bits.
  1. Delta Sigma ADC is inverting
    By selbstdual in forum mel PIC BASIC Pro
    Last Post: - 30th January 2007, 16:35
