Delta-Sigma-ADC in Assembler embedded in PBP, increasing resolution
Results 1 to 15 of 15
    In a world of german electrons
    Default Delta-Sigma-ADC in Assembler embedded in PBP, increasing resolution
    Good evening. I want to increase the code's resolution from 16bit to something deliberate. How do I have to change this code ?
    ...some code...
    ;* Filename: DeltaSig.asm
    ;* Author: Dan Butler
    ;* Company: Microchip Technology Inc.
    ;* Revision: 1.00
    ;* Date: 02 December 1998
    ;* Assembled using MPASM V2.20
    ;* Include Files:
    ;* p16C622.inc V1.01
    ;* Provides two functions implementing the Delta Sigma A2D.
    ;* InitDeltaSigA2D sets up the voltage reference and comparator
    ;* in the "idle" state.
    ;* DeltaSigA2D runs the actual conversion. Results provided in
    ;* result_l and result_h.
    ;* See An700 figure 2 for external circuitry required.
    ;* What's changed
    ;* Date Description of change
    #include <p16C622.inc>
    cblock
    result_l
    result_h
    counter:2
    endc
    InitDeltaSigA2D
    bsf STATUS,RP0
    movlw 0xEC
    movwf VRCON
    bcf PORTA,3 ;set comparator pin to output
    bcf STATUS,RP0
    movlw 0x06 ;set up for 2 analog comparators with common reference
    movwf CMCON
    ; Delta Sigma A2D
    ; The code below contains a lot of nops and goto next instruction. These
    ; are necessary to ensure that each pass through the loop takes the same
    ; amount of time, no matter the path through the code.
    DeltaSigA2D
    clrf counter
    clrf counter+1
    clrf result_l
    clrf result_h
    movlw 0x03 ; set up for 2 analog comparators with common reference
    movwf CMCON
    loop
    btfsc CMCON,C1OUT ; Is comparator high or low?
    goto complow ; Go the low route
    comphigh
    nop ; necessary to keep timing even
    bcf PORTA,3 ; PORTA.3 = 0
    incfsz result_l,f ; bump counter
    goto eat2cycles ;
    incf result_h,f ;
    goto endloop ;
    complow
    bsf PORTA,3 ; Comparator is low
    goto eat2cycles ; same here
    eat2cycles
    goto endloop ; eat 2 more cycles
    endloop
    incfsz counter,f ; Count this lap through the loop.
    goto eat5cycles ;
    incf counter+1,f ;
    movf counter+1,w ;
    andlw 0x04 ; Are we done? (We're done when bit2 of
    btfsc STATUS,Z ; the high order byte overflows to 1).
    goto loop ;
    goto exit
    eat5cycles
    goto $+1 ; more wasted time to keep the loops even
    nop ;
    goto loop ;
    exit
    movlw 0x06 ; set up for 2 analog comparators with common reference
    movwf CMCON
    blainecf's Avatar
    blainecf Guest
    Default More info please.
    By deliberate do you mean 8bits, 12 bits, 19bits??? Are you just wanting to know what was implicitly set (by default) that makes this 16 bit? What is your ultimate goal?
    bcf
    Thank you for your question.
    Exactly, I want to know how it subdivides in 1024 steps. Then it should be easy to change it to the desired value.
    well i certainely miss something here but, 1024 steps it's 10Bit. you said you want Increase your actual 16Bit resolution.. euh... i'm i wrong or what.
    By the way, why using the comparator when a real ADC give you already 10Bit resolution without headache, need few lines of code and no big additional hardware?
    Post
    These lines checks for 1024 passes through the loop and stops if reached.
    All you need to do is change ....
    andlw 0x04
    ..... to .......
    andlw 0x02 for 512(9 bits)
    andlw 0x08 for 2048(11 bits)
    andlw 0x10 for 4096(12 bits)
    andlw 0x20 for 8192(13 bits)
    andlw 0x40 for 16384(14 bits)
    andlw 0x80 for 32768(15 bits)
    If you need better resolution it can be done, but needs more changing in the code.
    /Ingvar
    Thank you so far.
    In my current application, I need around 750 steps. Surely I could use 1024 steps right now.
    I want to change it to the number of steps wanted, but I have not understood the relation yet.
    Please explain the math behind your examples.
    Post
    The code checks if bit 2 of the high byte of the wordsized variable "counter" is set. If it is, the program has looped around 1024 times, if not it keeps looping.
    There is really no math involved, 1024dec = 0400hex = 0000010000000000bin.
    You don't want to check for anything more complicated than if a single bit is being set or cleared. That would slow the ADconversion down, not something you want to do. I'm not saying it can't be done, just that it wouldn't be very easy. Especially if you don't know assembler and i get the impression that you don't.
    My advice is that you stick with 10 bits(1024) and when the conversion is complete you scale the result to your desired value. That can be done in various ways. Here's a few..... all will scale to 752.
    Dummy = ADresult * 752
    ScaledResult DIV32 1024
    ScaledResult = ADresult */ 188 '752/1024*256=188
    ScaledResult = ADresult ** 48128 '752/1024*65536=48128
    /Ingvar
    What about using
    andlw 0x2F0 ; Are we done? (We're done when bit2 of
    Question
    No, you can only check one byte(8bits) in one go. You're also trying to check several bits at the same time, only one is "allowed". If you really MUST check for something more complicated you'll need to rewrite the code yourself. Certanly possible but nothing i will help you with.
    Good luck.
    /Ingvar
    PS. Is there a perticular reason why you can't use 10 bits and scale the result as i showed you in my last post? DS.
    Where is the result stored - in result_l or result_h or are they the same ?
    At U = Umax there should be a value of 1024.
    Post
    Result_h is the high byte(8bits) of the wordsized(16bits) result. Result_l holds the lower 8 bits.
    I don't understand this. How do you combine these two to get a Dez-number between 0 and 1023 ?
    Red face
    Ok, time for somebody else to step in. I don't have the patience, time and/or languageskills to explain how hex, binary and decimal correlates. I recommend that you buy a book that expalins the basics of "microcontrolling". Can't give you any advice on good books since i haven't needed one for 20 years.
    Good luck
    /Ingvar
    Haven't followed this from the beginning but I'll jump in here real quick.
    A word is 16bits. A byte is 8bits. A word consists of 2bytes a high and a low. To combine 2 bytes into a word you can do:
    MyWordResult var WORD
    MyWordResult = Result_h * 256 + Result_l
    HSEROUT [#MyWordResult,10]
    If Result_h is 100 in decimal and Result_l is 25 in decimal. Your result would be 25625 in decimal. Or if you like in binary.
             H I G H     L  O  W
             B Y T E     B Y T E
    MSB---> 01100100  00011001 <----LSB
    See? The high byte is 100 and the low byte is 25.
    Since the most significant bit in the low byte equals to 128 the least significant bit in the high byte equals to 256. That is why you multiply the highbyte by 256.
    Or seeing it as 16bit word:
    LSB MSB
    1+0+0+8+16+0+0+0+0+0+1024+0+0+8192+16384+0 = 25625
    /Henrik Olsson.
    This is what I was looking for. Plain and simple. Thank you.
  1. Delta Sigma ADC is inverting
    By selbstdual in forum mel PIC BASIC Pro
    Last Post: - 30th January 2007, 16:35
