Encoder problem
Results 1 to 7 of 7
Thread: Encoder problem
Threaded View
    Mar 2006
    INDIA
    Default Encoder problem
    Hi all
    I am using 900 ppr encoder for length measurements. i using 595 chip to show display and rs232 output for x,y plotting. when encoder rotate on 5 rpm, it is work. But when encoder run above 5 rpm, pulses are missing.
    Where my codes are wrong ?
    '---- chip 16F877 i/p 20 MHZ ---"
    DEFINE OSC 12
    INCLUDE "MODEDEFS.BAS"
    ADCON1 = 7
    INPUT PORTA.0
    TRISA=0
    TRISD = 0
    TRISC = 0
    TRISE =0
    OUTPUT PORTD.2
    OUTPUT PORTD.3
    OUTPUT PORTD.4
    OUTPUT PORTC.4
    Symbol HC_latch = PORTE.0 ' pin 8
    symbol HC_Data = PORTE.1 ' pin 9
    SYMBOL HC_Clk = PORTE.2 ' pin 10
    B1 VAR BYTE
    B2 VAR BYTE
    B3 VAR BYTE
    B4 VAR BYTE
    B5 VAR BYTE
    DIGIT1 VAR BYTE
    DIGIT2 VAR BYTE
    DIGIT3 VAR BYTE
    DIGIT4 VAR BYTE
    DIGIT5 VAR BYTE
    DIGIT6 VAR BYTE
    MASK VAR BYTE
    B1 = 0
    B2 = 0
    B3 = 0
    B4 = 0
    B5 = 0
    E1 VAR BYTE
    E2 VAR BYTE
    E3 VAR BYTE
    E4 VAR BYTE
    E5 VAR BYTE
    OPTION_REG = %00000000
    On Interrupt Goto myint
    INTCON = $90
    IF PORTA.0 = 1 THEN NINE
    LOOP: serOUT PORTC.6,T9600,[#b5,#b4,#b3,#b2,#b1,13]
    DIGIT1 = B1
    LOOKUP DIGIT1,[$7E,$18,$6D,$3D,$1B,$37,$77,$1C,$7F,$3F],MASK
    E1 = MASK
    DIGIT2 = B2
    LOOKUP DIGIT2,[$7E,$18,$6D,$3D,$1B,$37,$77,$1C,$7F,$3F],MASK
    E2 = MASK
    DIGIT3 = B3
    LOOKUP DIGIT3,[$7E,$18,$6D,$3D,$1B,$37,$77,$1C,$7F,$3F],MASK
    E3 = MASK
    DIGIT4 = B4
    LOOKUP DIGIT4,[$7E,$18,$6D,$3D,$1B,$37,$77,$1C,$7F,$3F],MASK
    E4 = MASK
    DIGIT5 = B5
    LOOKUP DIGIT5,[$7E,$18,$6D,$3D,$1B,$37,$77,$1C,$7F,$3F],MASK
    E5 = MASK
    HC_Latch=0
    shiftout HC_data, HC_Clk, LSBFIRST,[E1,E2,E3,E4,E5,$7E]
    pauseus 1
    HC_Latch=1
    GOTO LOOP
    Disable
    myint:
    FF: B1 = B1 + 1
    IF B1 > 9 THEN TWO
    goto HH
    TWO: B1=0
    B2 = B2+1
    IF B2 > 9 THEN THREE
    goto HH
    THREE: B1 = 0
    B2 = 0
    B3 = B3+1
    IF B3 > 9 THEN FOUR
    goto HH
    FOUR: B1 = 0
    B2 = 0
    B3 = 0
    B4 = B4+1
    IF B4 > 9 THEN FIVE
    goto HH
    FIVE: B1 = 0
    B2 = 0
    B3 = 0
    B4 = 0
    B5 = B5+1
    IF B5 > 9 THEN NINE
    goto HH
    NINE: B1 = 0
    B2 = 0
    B3 = 0
    B4 = 0
    B5 = 0
    goto HH
    HH:
    INTCON.1 = 0
    resume
    Enable
  1. Quadrature encoder and ASM Interrupts. questions..
    By godfodder in forum mel PIC BASIC Pro
    Last Post: - 17th March 2013, 15:45
  2. Instant Int and encoder (Elect. Gearing)
    Last Post: - 29th November 2009, 03:29
  3. Problem implement "Henrik" incPID
    By phoenix_1 in forum mel PIC BASIC Pro
    Last Post: - 26th September 2009, 15:36
  4. USART Problem , but don't know where, in pc? or in PIC?
    Last Post: - 15th July 2007, 09:12
  5. encoder wowes
    By wallaby in forum mel PIC BASIC Pro
    Last Post: - 6th December 2005, 22:56
