Quad encoder problems
Results 1 to 40 of 52
    Sep 2006
    I got it to compile!!! Using microcode studio. Happy dance. LOL
    On a down note, it dosnt do anything. The LCD has a value of 0 for both encoders. I tried switching the a&b channels and still nothing. I checked all my connections and everything looks good. I am using a 16F876A now instead of the 16F628. I need to check those pins and see if anything needs to be turned off.
    I think I am getting close!
    Smitty
    May 2006
    Del Rio, TX, USA
    Quote Originally Posted by smitty505000
    Once you check over the hardware to eliminate any problems there, then post the code you are using. Lots of folks can help out with that!
    Hey Steve, seems we use the same source for this 'Dancing Awesome'
    <img src="http://www.picbasic.co.uk/forum/attachment.php?attachmentid=881&d=1148640458">
    Sep 2006
    LOL, Thanks for the help and support guys!
    Here is the run down
    Code from Steve on post 12 works but looses count if rotated too fast so I know the circuit is good.
    I then went to the code in post 6 with both asm routines and compiled it with microcode studio. Compiled fine. The only things I changed in the code from post 6 was adding:
    DEFINE OSC 20
    PAUSE 1000
    SEROUT2 on PORTB.0 FOR LCD clear
    SEROUT2 ON PORTB.0 FOR DISPLAY
    Here it is:
    Old_Bits VAR BYTE
    New_Bits VAR BYTE
    RotEnc1_val VAR BYTE 'Connected to PORTB<4:5>
    RotEnc2_val VAR BYTE 'Connected to PORTB<6:7>
    TRISB = %11110000
    RotEncDir VAR BIT
    ' SETUP YOUR LCD HERE!!!
    DEFINE OSC 20
    PAUSE 1000 'Pause for LCD Power up
    SEROUT2 PORTB.0, 84,[254, 88] 'Clear LCD
    INCLUDE "DT_INTS-14.bas" ' Base Interrupt System
    INCLUDE "ReEnterPBP.bas" ' Include if using PBP interrupts
    INT_Handler INT_INT, _Rot_Encoder, PBP, yes
    @ INT_ENABLE RBC_INT ;RB Port Change Interrupt
    Old_Bits = PORTB & (%11110000)
    SEROUT2 PORTB.0, 84,[254, 71, 1, 1, "ROT1:", DEC2 RotEnc1_val,"ROT2:",_
    DEC2 RotEnc2_val]
    pause 10
    GOTO Main
    '---[RBC - interrupt handler]---------------------------------------------------
    Rot_Encoder:
    New_Bits = PORTB & (%11110000)
    IF (New_Bits & %00110000) = (Old_Bits & %00110000) then No_Change_Rot1
    RotEncDir = New_Bits.5 ^ Old_Bits.4
    if RotEncDir = 1 then
    RotEnc1_val = RotEnc1_val + 1
    if RotEnc1_val = 36 then RotEnc1_val = 0
    RotEnc1_val = RotEnc1_val - 1
    if RotEnc1_val = 255 then RotEnc1_val = 35
    No_Change_Rot1:
    IF (New_Bits & %11000000) = (Old_Bits & %11000000) then DoneRotEnc
    RotEncDir = New_Bits.7 ^ Old_Bits.6
    RotEnc2_val = RotEnc2_val + 1
    if RotEnc2_val = 36 then RotEnc2_val = 0
    RotEnc2_val = RotEnc2_val - 1
    if RotEnc2_val = 255 then RotEnc2_val = 35
    DoneRotEnc:
    Old_Bits = New_Bits
    @ INT_RETURN
    The LCD comes up and displays ok. Then when I rotate an encoder, sometimes I get a little garbage on the screen and then it just seams to hang. I can go thru many restarts before the LCD will display properly again. It kinda seams like the chip is stuck. Is that possible even though I disconnect power and then reconnect? Is the pic holding something in memory where it hangs? I am using a 16F876A
    Thanks guys!
    Smitty
    May 2006
    Del Rio, TX, USA
    OK, I found an error in the interrupt setup. Make the change highlighted in red.
              INT_Handler RBC_INT, _Rot_Encoder, PBP, yes
    I tried this out on a 16F877a (since I don't have your model). Worked fine with the one encoder I have available hooked to Rot1. Don't see any reason it wouldn't work with both hooked up.
    May 2006
    Del Rio, TX, USA
    Default One other thing...
    Since you are using a serial LCD and software based serial routine, the interrupts will be disrupting the timing of the serial output. I would recommend using HSEROUT. The timing won't be affected with the interrupts.
    EDIT:
    Here is how you can do this:
    1) Switch your serial cable to RB2 (pin 8)
    3) Setup the HSER defines:
    'Setup for 9600 baud
    ' Set transmit register to TXEN =1 (TX enabled) and BRGH = 1
         DEFINE HSER_TXSTA	24h
    ' Set baud rate
         DEFINE HSER_BAUD	9600
    3) Change your SEROUT2 commands to HSEROUT.
    HSEROUT [254, 88] 'Clear LCD
    and
    HSEROUT [254, 71, 1, 1, "ROT1:", DEC2 RotEnc1_val," ROT2:", DEC2 RotEnc2_val]
    Sep 2006
    I think someone dosnt want this to work
    I did the hserout just as you said and still got garbage. I then checked the pbp manual and double checked the define's. all ok. Wait a sec, the 16f876a has the usart tx on pin c6! Right? So I moved the lcd serial line to c6 and still got garbage! What is going on! So then I programed a simple code into the pic to just do a hserout to print to the lcd. I used the proper define's and still got garbage. At this point I am thinking what the heck is going on. So then went back to a simple program to print on the lcd with the serout2 command just to check the lcd. And sure enough garbage! Is the lcd bad? Well I then hooked it to the pc and ran a program that tests it and sure enough the lcd is shot! Not sure what happened. I never hooked it up reverse polarity. Is it possible that with the initial garbage coming out of the pic it sent something to the lcd that screwed something up? I am totaly scratching my head. LOL
    The only thing that I might have done is connect the serial line going to the lcd to 5v. Would that kill it?
    I am going to try the my old parallel lcd and see what happens.
    Thank you for putting up with me this long. I will get this thing running if it kills me! LOL
    Smitty
  1. Quadrature encoder and ASM Interrupts. questions..
    By godfodder in forum mel PIC BASIC Pro
    Last Post: - 17th March 2013, 15:45
  2. Instant Int and encoder (Elect. Gearing)
    Last Post: - 29th November 2009, 03:29
  3. encoder HEDL 5540
    By kutsi in forum mel PIC BASIC Pro
    Last Post: - 11th June 2007, 15:00
  4. quad encoders
    Last Post: - 13th March 2007, 18:49
  5. encoder wowes
    By wallaby in forum mel PIC BASIC Pro
    Last Post: - 6th December 2005, 22:56
