Quad encoder problems
Results 1 to 40 of 52
Threaded View
  1. #16
    Quote Originally Posted by smitty505000
    The encoders output a positive voltage between ~1.85 and 5 and I have 4.7K resistors pulled to ground on each channel.
    So it's never 0V? @1.85 you're probably sometimes in-between Low and High logic Level. You may need to 'filter' it a little bit to avoid oddity.
    1.Use the internal voltage comparator, set the threshold and use their interrupt to increment the counter.
    OR
    2.try something like...
    <img src="http://www.picbasic.co.uk/forum/attachment.php?attachmentid=1067&stc=1&d=115794620 6">
    maybe one diode could be enough... maybe not
    HTH
  1. Quadrature encoder and ASM Interrupts. questions..
    By godfodder in forum mel PIC BASIC Pro
    Last Post: - 17th March 2013, 15:45
  2. Instant Int and encoder (Elect. Gearing)
    Last Post: - 29th November 2009, 03:29
  3. encoder HEDL 5540
    By kutsi in forum mel PIC BASIC Pro
    Last Post: - 11th June 2007, 15:00
  4. quad encoders
    Last Post: - 13th March 2007, 18:49
  5. encoder wowes
    By wallaby in forum mel PIC BASIC Pro
    Last Post: - 6th December 2005, 22:56
