Weak pullups failing?
Results 1 to 14 of 14
    Quote Originally Posted by Melanie
    There is no problem with weak pull-ups on switches...
    How are you enabling them?
    Apart from OPTION_REG you also have to set them in the WPUA register in this chip.
    Hi Melanie,
    (this is a 16F676)
    OPTION_REG.7 = 0 ' ENABLE WEAK PULLUPS
    WPUA = 255 ' ALL PULLUPS ON
    Since a fresh chip works flawlessly, I do not think the issue is to do with the code or configuration. From your mail and the earlier ones, I gather that this is an extremely rare happenning. Just how rare is my worry; often enough to justify external pullups?
    Anand
    If this is anything other than a random happening then I'm in deep sh*t, because my top ten best selling designs all use weak pull-up's. Never, ever had a single return that has a fault on a pull-up input - and that's after years of sales...
    mmm, i don't know but you really have a PIC with a faulty internal pull-up?
    If you add a external pull-up it works?
    Is there any chance somewhere in your code some pin change from input to output? in this case it could disable some internal pull-up but...
    Maybe some electrostatic discharge burned it? but if so... i guess it should go deeper than only the internal weak pull-up no? Strange...
    Quote Originally Posted by mister_e
    Yes, I think that last part should be it. I have an ICSP arrangement, with +5 to the target being supplied exclusively from an external supply. At times, when I'm not working on the project, this supply is switched off. And the programmer (an Epic clone), still connected to the PC, keeps the Vcc (not an issue in this case) *and* Vpp high, unless the programmer s/w (WinPic800) is initialised (loaded). The Pic therefore is exposed to Vpp without getting Vcc.
    I think this kind of abuse might have caused the damage.
    And yes, I confirm that external pullups work.
    malc-c's Avatar
    malc-c Guest
    Do you have a 0.1uF capacitor across the supply lines as near to the PIC. I found that without this I would sometimes have strange issues with the way a PIC would behave. Maybe this has some bearing on the problem here ?
  1. 16C65B internal pullups
    By Michael in forum mel PIC BASIC Pro
    Last Post: - 20th January 2009, 17:26
  2. Pullups and pulldows
    Last Post: - 1st April 2008, 22:15
  3. dual 7-segment countdown timer code
    By dr.ragh in forum mel PIC BASIC Pro
    Last Post: - 30th April 2007, 14:19
  4. Effects of Current Draw Using Internal VS External PullUps
    By rixtalbert in forum mel PIC BASIC Pro
    Last Post: - 16th September 2006, 10:43
  5. Pullups DS18S20 and DS1307
    By DynamoBen in forum General
    Last Post: - 27th July 2006, 19:32
