LCD backlight overheats 7805
Results 1 to 22 of 22
    Jul 2005
    Thx for the reply's everybody.
    I chose the 7805 part for my project because i had one on hand (many on hand), and also because the end goal for my little project involves around 12 IC's, and a backlight.
    The project involves 1 pic 16F767 running@20mhz which aquires data from several 74LS151 8-1 data selector IC's.
    The data is "line status" information coming over 2 wires and 1 common for each "phone line". The pic runs the address sequencing and aquires the bit information and then transmits it to PC software.
    The inputs on the 74LS151 IC's are tied high and are "commoned" to ground. Active Low.
    I decided to Add on an LCD connected 16F84a. It is to receive serial output from the 16F767 PIC and print certain information to the LCD display (totals for each of the 4 states of the phone line).
    So lets say I move the lcd backlightpower to the source before my 7805 regulator which is powered by a 12v wall wart adapter. Do i need a voltage divider before feeding the power to the LCD backlight?
    I think the ultimate solution would be to have a button on the 16F84a that turns on the backlight. So i imagine this would involve an interupt? But lets start off by powering the backlight..
    Feb 2003
    Quote Originally Posted by RYTECH
    You just need a bigger resistor instead of the 11 ohm you currently have.
    With your 11 ohm resistor you have 50mA flowing through the backlight.
    11 * 0.05 = 0.55V dropped across the resistor so your LED backlight has a forward voltage of 4.45 volts.
    For a 12v supply you need the resistor to drop 7.55v
    7.55/0.05 = 151 so 150 ohm 0.5 watt resistor for 12V supply @ 50mA
    For the 18v supply you need the resistor to drop 13.55v
    13.55 / 0.05 = 271 so 270 ohm 1 watt resistor 18V supply @ 50mA
    Keith
    www.diyha.co.uk
    www.kat5.tv
    Jul 2005
    thx for the info
    Jun 2005
    Wisconsin
    Just for the record, I ran into the same situation recently. I end up tying the backlight to 12V. Works well and keeps the 7805 nice a cool.
    Mar 2006
    Hyderabad (India)
    Hi
    i saw another application where 47E is used instead of 11E in series to backlit LEDs circuit
    However perhaps it is better Rytech cold analyze the current breakup-- may be the current is draining thro another circuit path
    Sarma
    Mar 2006
    Hyderabad (India)
    Thumbs down
    Quote Originally Posted by keithdoxey View Post
    having regard to RYTECH, i wonder whther 78L05 was used and if so proper termination adopted or Not?
    afterall for 50mA with 12V input, the device need not be hot. let RYTECH measure the current at input 12V point and it will really speak.
    Sarma
    Post
    Hi, Sarma
    I just have MEASURED 3v9 @ 50 mA on one of my LCD Backlight ...
    so, ...
    ( 12v - 3.9v ) x .05 = 0.4 W to be dissipated ...
    now, as you do, pluggeg in the 5v with 11 Ohms
    ( 5 - 3.9 ) /11 = 100 mA !!!
    so, your 7805 is then overcharged and is close to it's maximun dissipated power before shutdown ( 130°C internal ? ) !!!
    Try a 22 Ohm resistor and everything might be Ok !!!
    Ohm's law will still make ink flow ...
    Talking
    really satanic !!!
    Mar 2006
    Hyderabad (India)
    Acetronics is right in recommending 22ohms and i saw other designs (IK3OIL's frequency counter using LCD display) indicating backlit LCDs draw 60 mA and recommend 7805 but NOT 78L05. No heatsink is noticed.
    Hi DynamoBen,
    did you use 12V ,7805 and 11ohm resistor for Backlit? Still find No heat?
    Sarma
    Default Nice
    Thanks mister_e
  1. Is this code not initialising the LCD properly?
    By Platypus in forum mel PIC BASIC Pro
    Last Post: - 30th January 2010, 20:14
  2. LCD Backlight Proper Wiring
    By DavyJones in forum General
    Last Post: - 27th July 2009, 00:01
  3. Play with LCD on PICDEM
    Last Post: - 22nd August 2008, 17:56
  4. PIC16F684 + LCD to use the 256bytes of EEPROM - HELP
    Last Post: - 7th March 2008, 15:19
  5. Easy LCD BackLight
    By Melanie in forum Schematics
    Last Post: - 17th October 2004, 14:18
