LCD backlight overheats 7805
Results 1 to 22 of 22
    Feb 2003
    Quote Originally Posted by RYTECH
    The lcd datasheet doesnt say much about anything.
    i metered the lcd backlight - 50 milliamps
    The only other things powered off the 7805 is the LCD itself, a pic 16F84a.
    The current rating is 1amp on the 7805, no heatsink is attached.
    Input voltage is between 12 and 18v. When the LCD backlight is unattached, the 7805 remains cool, the circuit and lcd function normally.
    I think you need to add a heatsink. Your regulator is dropping upto 13V with worst case supply voltage. At 50mA the LCD will be causing it to disipate an additional 0.65W with only the tab to get rid of the heat.
    The 7805 datasheet I have just looked at says that maximum power dissipation is "Internally Limited" so it *shouldnt* self destruct but best not risk it
    What is the TOTAL current you are drawing from the supply.
    Keith
    www.diyha.co.uk
    www.kat5.tv
    Jul 2005
    LCD datasheet
    just use a heat sink could help... but i would check what's happen at the 7805 input first with a scope. Is this really clean? is this really between the voltage you mentionned OR it have also up to 20 volts peak...
    My best suggestion will be to change your PIC to have a PWM out and use it. Take the output, send it to a transistor. The LCD voltage will be taken at the input of the voltage regulator. This way, you will reduce heat.
    a 16F628 is just perfect, cheaper and also give few free i/o if the internal OSC is enough. 1 more if you don't need the MCLR pin.
    I find that even with quite low current consumption the 7805 dissipates sufficient heat to require a heatsink and to that extent I avoid that part. On the other hand, the 78L05 is great. Small TO92 footprint, low heat dissipation... yes it's spec'd at 100mA, but I seldom draw more than 50mA from one, and I'd fit two... one for the +5v for your microprocessor and logic, and the other for the Backlight. Two or three 78L05's take up less real-estate as a single 7805 horizontal with a heatsink and in total cost less. Actually, most backlights can happilly run from an unregulated supply provided you suitably current limit them.
    Jul 2005
    Thx for the reply's everybody.
    I chose the 7805 part for my project because i had one on hand (many on hand), and also because the end goal for my little project involves around 12 IC's, and a backlight.
    The project involves 1 pic 16F767 running@20mhz which aquires data from several 74LS151 8-1 data selector IC's.
    The data is "line status" information coming over 2 wires and 1 common for each "phone line". The pic runs the address sequencing and aquires the bit information and then transmits it to PC software.
    The inputs on the 74LS151 IC's are tied high and are "commoned" to ground. Active Low.
    I decided to Add on an LCD connected 16F84a. It is to receive serial output from the 16F767 PIC and print certain information to the LCD display (totals for each of the 4 states of the phone line).
    So lets say I move the lcd backlightpower to the source before my 7805 regulator which is powered by a 12v wall wart adapter. Do i need a voltage divider before feeding the power to the LCD backlight?
    I think the ultimate solution would be to have a button on the 16F84a that turns on the backlight. So i imagine this would involve an interupt? But lets start off by powering the backlight..
    Feb 2003
    You just need a bigger resistor instead of the 11 ohm you currently have.
    With your 11 ohm resistor you have 50mA flowing through the backlight.
    11 * 0.05 = 0.55V dropped across the resistor so your LED backlight has a forward voltage of 4.45 volts.
    For a 12v supply you need the resistor to drop 7.55v
    7.55/0.05 = 151 so 150 ohm 0.5 watt resistor for 12V supply @ 50mA
    For the 18v supply you need the resistor to drop 13.55v
    13.55 / 0.05 = 271 so 270 ohm 1 watt resistor 18V supply @ 50mA
    Keith
    www.diyha.co.uk
    www.kat5.tv
    Jul 2005
    thx for the info
    Mar 2006
    Hyderabad (India)
    Thumbs down
    Quote Originally Posted by keithdoxey View Post
    having regard to RYTECH, i wonder whther 78L05 was used and if so proper termination adopted or Not?
    afterall for 50mA with 12V input, the device need not be hot. let RYTECH measure the current at input 12V point and it will really speak.
    Sarma
    Omaha, Nebraska USA
    I find that even with quite low current consumption the 7805 dissipates sufficient heat to require a heatsink and to that extent I avoid that part. On the other hand, the 78L05 is great. Small TO92 footprint, low heat dissipation... yes it's spec'd at 100mA, but I seldom draw more than 50mA from one, and I'd fit two... one for the +5v for your microprocessor and logic, and the other for the Backlight. Two or three 78L05's take up less real-estate as a single 7805 horizontal with a heatsink and in total cost less. Actually, most backlights can happily run from an unregulated supply provided you suitably current limit them.
    This is such a great idea, and not just for this application!
    Russ
    N0EVC, xWB6ONT, xWN6ONT
    "Easy to use" is easy to say.
  1. Is this code not initialising the LCD properly?
    By Platypus in forum mel PIC BASIC Pro
    Last Post: - 30th January 2010, 20:14
  2. LCD Backlight Proper Wiring
    By DavyJones in forum General
    Last Post: - 27th July 2009, 00:01
  3. Play with LCD on PICDEM
    Last Post: - 22nd August 2008, 17:56
  4. PIC16F684 + LCD to use the 256bytes of EEPROM - HELP
    Last Post: - 7th March 2008, 15:19
  5. Easy LCD BackLight
    By Melanie in forum Schematics
    Last Post: - 17th October 2004, 14:18
