pf compiler problem
Results 1 to 3 of 3
    dave_c's Avatar
    dave_c Guest
    Default pf compiler problem
    G'day All
    I've trying to use the 4functn.bas and FP20.Bas in a program for 16f876, I've placed all the files needed in the project folder as per the Melab's readme FP.zip documentation, setup mpasm as my assembler in PBP picbasic options and PBP as the compiler
    The only thing i changed was to add the below first 2 defines and chage the lcd to port b from the original ports for a 877 and the assembler error i get is..
    error[113]c:\pbp\pbppic14.lib 2668:Symbol not previously defined [portb]
    can some one help with what this means and how i might fix it??
    Thanks Dave
    Define LOADER_USED 1
    Define OSC 20
    include "fp20.bas"
    DEFINE LCD_DREG Portb
    DEFINE LCD_DBIT 0
    DEFINE LCD_EREG Portb
    DEFINE LCD_EBIT 4
    DEFINE LCD_RSREG Portb
    DEFINE LCD_RSBIT 5
    DEFINE LCD_BITS 4
    DEFINE LCD_LINES 2
    1. Have you tried it with Portb all in UPPERCASE in the LCD define statements?
    2. Are you trying to compile your program for a PIC that hasn't got PORTB?... eg you intend to compile for 16F675 but you've got a typo specifying 12F675?
    dave_c's Avatar
    dave_c Guest
    Thanks Melanie,
    quirky thing isn't it ....! yep the change to uppercase solved that problem now to put it into action. It's this type of problem that drives me crazy.
    typo's have been a problem as can be seen from the thread title
  1. Problem to compile my program
    By wagner in forum Off Topic
    Last Post: - 7th July 2008, 21:17
  2. compiler problem
    Last Post: - 25th April 2008, 02:29
  3. USART Problem , but don't know where, in pc? or in PIC?
  4. Pro Compiler Problem - Cancelled
    By Homerclese in forum mel PIC BASIC Pro
    Last Post: - 18th March 2007, 06:48
  5. Replies: 4
    Last Post: - 9th June 2006, 00:15
