Per the datasheet, Section 17.0, the maximum voltage on RA3 is VDD+0.3V. In your case that would be 5.0+0.3=5.3V. 10V will most likely damage the PIC - do not do that. If your analog signal is larger than 5.0 V, consider using a voltage divider to reduce the analog signal. Please reply if you need more input.
