[218] Address Limit of 7FFh Exceeded
Results 1 to 4 of 4
    Vando's Avatar
    Vando Guest
    This is the batch file i use to run PBP.
    Is there any reason why -p16F648A wouldn't work?
    @echo off
    REM - File dir
    cd C:\Documents and Settings\Daniel\My Documents\Work\PIC\PicBasic Pro\projects\heat_main\
    REM - PIC - Programme name
    pbp -p16F648A main
    pause
    Vando's Avatar
    Vando Guest
    I found the problem.
    I had copied
    @ DEVICE pic16F648A, INTRC_OSC_NOCLKOUT
    @ DEVICE pic16F648A, WDT_ON
    etc.
    from a pic16F628A example and had forgot to change the pic to a 16F648A.
  1. Instant Interrupts - Revisited
    Last Post: - 17th February 2016, 23:14
  2. Bit/Byte array for Hserin/Hserout
    By mrx23 in forum mel PIC BASIC Pro
    Last Post: - 2nd September 2006, 00:07
  3. Jump into eeprom address
    By Lotondo in forum mel PIC BASIC Pro
    Last Post: - 22nd April 2006, 19:29
  4. RF Transmitter
    By et_Fong in forum mel PIC BASIC Pro
    Last Post: - 27th October 2005, 17:34
  5. 18f452 internal eprom help
    Last Post: - 13th July 2004, 16:50
