[218] Address Limit of 7FFh Exceeded
Results 1 to 4 of 4
    Vando's Avatar
    Vando Guest
    Default [218] Address Limit of 7FFh Exceeded
    I get this error when compiling, I have just crossed over the 2k barrier.
    I have a 16F648A which has 4k of program memory and I'm using PicBasic Pro Compiler 2.46.
    Can anyone tell me why I'm getting this error?
    Have you told the compiler the correct PIC you're using? 7FFh is 2k, so it looks like it thinks that's the limit.
    Vando's Avatar
    Vando Guest
    This is the batch file i use to run PBP.
    Is there any reason why -p16F648A wouldn't work?
    @echo off
    REM - File dir
    cd C:\Documents and Settings\Daniel\My Documents\Work\PIC\PicBasic Pro\projects\heat_main\
    REM - PIC - Programme name
    pbp -p16F648A main
    pause
    Vando's Avatar
    Vando Guest
    I found the problem.
    I had copied
    @ DEVICE pic16F648A, INTRC_OSC_NOCLKOUT
    @ DEVICE pic16F648A, WDT_ON
    etc.
    from a pic16F628A example and had forgot to change the pic to a 16F648A.
  1. Instant Interrupts - Revisited
    Last Post: - 17th February 2016, 23:14
  2. Bit/Byte array for Hserin/Hserout
    By mrx23 in forum mel PIC BASIC Pro
    Last Post: - 2nd September 2006, 00:07
  3. Jump into eeprom address
    By Lotondo in forum mel PIC BASIC Pro
    Last Post: - 22nd April 2006, 19:29
  4. RF Transmitter
    By et_Fong in forum mel PIC BASIC Pro
    Last Post: - 27th October 2005, 17:34
  5. 18f452 internal eprom help
    Last Post: - 13th July 2004, 16:50
