Oscillator configuration for PIC18f2455
Results 1 to 6 of 6
    Fritzengruber's Avatar
    Fritzengruber Guest
    Default Oscillator configuration for PIC18f2455
    Hi everyone,
    I am new to the world of Pic processors, and am having a bit of a problem. I am using a pic18f2455 on a custom made board to act as a motor controller by switching FETs, and have noticed that the chip seems to be running at 1/8th of the speed it should (a pause 1000 pauses 8 seconds instead of 1). I am not using the USB facilities, so I do not have an external oscillator,but am planning on just using the 8mhz internal oscillator. Using the command
    DEFINE OSC 8
    in picbasic doesnt seem to work, and leaving the oscillator speed undefined causes the chip to run at 1/4 speed.
    Is there some other configuration option I should be changing? Do I have to change the config bits?
    I just got this job after the guy before me was arrested, so I am having to pick up where he left off.
    Thanks for your help
    Fritz
    Jan 2006
    Istanbul
    Why arrested?
    Was he working on something illegal?
    Are you continuing on his work?
    Fritzengruber Guest
    Yes he was, but it had nothing to do with the project
    DEFINE OSC 8
    sur eit have something to do with the config fuses... open then 18F2455.inc file in the PBP folder... you'll find those
            __CONFIG    _CONFIG1L, _PLLDIV_5_1L & _CPUDIV_OSC1_PLL2_1L & _USBDIV_2_1L
            __CONFIG    _CONFIG1H, _FOSC_HSPLL_HS_1H
            __CONFIG    _CONFIG3H, _PBADEN_OFF_3H
            __CONFIG    _CONFIG4L, _LVP_OFF_4L & _XINST_OFF_4L
    change them to
    [code]
    try to change with
            __CONFIG    _FOSC_INTOSCIO_EC_1H
    and at the top of your code add
    DEFINE OSC 8
    OSCCON=%01110000
    it should work... i should. Refer to the datasheet section 2.0
    mark_wotton's Avatar
    mark_wotton Guest
    Default Thanks!
    On behalf of Fritzengruber, who is now busily removing no-longer-needed 20MHz oscillator crystals, thank you very much - you've saved our bacon. If you're in Doha any time in the next 4 months, or in Sydney after that, look me up (Mark Wotton) and I'll buy you a beer or twelve.
    Cheers
    Mark
    Twelve should be enough to start
    Nice to know it's working!
