PIC 12c509 - No External timing components
Results 1 to 4 of 4
    stay_aliveuk's Avatar
    stay_aliveuk Guest
    Default PIC 12c509 - No External timing components
    I am new to this area of electronics but have done a bit with the 16c84. I have just noticed from some schematics I stumbled across that you do not have to have external timing components. This can apparently be done though software. Does anyone have any samples of do they need to be specific to a program?
    Best regards
    niels's Avatar
    niels Guest
    I didn't think that the 16c84 had an internal oscillator. Some chips (such as the 16F88 do). These are configured when you program the PIC.
    you can run the 12C509 by setting the according configuration fuses in your code or before programming it... do it in your code, it's handy and easy. The whole thing is explain in the following thread.
    Feb 2003
    Salt Lake City, Utah USA
    Smile
    In additon to what the others have said ... I went to MELabs website and used their PIC search tool to find all PICs that have internal oscillator capabilities. You can see these here:
    http://tinyurl.com/rjfux
    As far as specific examples, I have a picture posted (link below) showing a serial interface to a custom display (with no external oscillator)
    http://tinyurl.com/rtgtm
    a small code snippet is included under the picture. As the others have noted, the choice to use the internal or external is made when you program the chip. Follow the links they provided for more information on that.
    Good Luck
    Paul Borgmeier
    Salt Lake City, UT
    USA
    __________________
  1. Please help to change pic on asm 12c509
    By davids in forum mel PIC BASIC Pro
    Last Post: - 6th February 2010, 18:16
  2. Pic not timing correctly
    By atwoz in forum General
    Last Post: - 5th December 2007, 22:25
  3. About timing in pic basic pro
    By din_kt in forum mel PIC BASIC Pro
    Last Post: - 4th October 2007, 04:09
  4. PIC AD + Vref- using external IC
    By jorge in forum mel PIC BASIC Pro
    Last Post: - 19th June 2007, 03:05
