Delay problem
Results 1 to 12 of 12
Thread: Delay problem
    Sep 2006
    Default Delay problem
    Hi all, my first post on this great site, so be gentle with me...
    I need to embed a program in the Olimex PIC I/O board. It has 4 Inputs and 4 relay Outputs. I am using a 16F628A. Using PBP. I use several of these boards in my little welding shop and always seem to have the same problem with Basic language programming. The relay response time when the input changes state is affected by the Pause command. I want to turn on a vacuum, pause, turn on a light, pause, turn on a power feed, pause, turn on a saw. I flip the switch on -vac comes on followed by the other relays OK. But there is that darned delay of up to 3 seconds at the beginning of each cycle. When the switch is turned off the saw MUST shut down immediately. But there is that darned delay again. The more Pause I include in the program the more delay I get at the beginning of each cycle. I can program the same hardware in Ladder Logic and not get the delay but I want to use PBP. Please tell me what the fix is. It's usually simple, I know, but 6 Saturdays have been invested with little result.
    My latest (cleaned up) incantation:
    pause 50
    define OSC 20
    CMCON = 7 ' digital I/O
    TRISA = %00010000
    TRISB = %00111001
    counter var word
    loop:
    toggle portb.5 'Cycle on/off Power-On LED
    if portb.0 = 1 then 'Switch is Off
    gosub sub1
    portb.0 = 0 'Switch is On
    gosub sub2
    goto loop
    sub1:
    low 11 'Turn Off SAW immediately
    gosub delay
    low 10 'Turn Off power feed
    gosub delay
    low 9 'Turn Off Light
    gosub delay
    low 8 'Turn Off Vacuum
    goto loop
    sub2:
    high 8 'Turn On Vacuum
    gosub delay
    high 9 'Turn On Light
    gosub delay
    high 10 'Turn On Power Feed
    gosub delay
    high 11 'Turn On SAW
    goto loop
    delay:
    counter=32
    repeat
    pause 50
    counter=counter-1
    until counter=0
    As I said, this works, but when I flip the switch off I really need the saw to stop immediately. Thanks to all of you. lloyd778
    Well isn't the important part NOT to have any delays?
    loop:
    	if portb.0 = 1 then	' Switch is OFF
    		gosub sub2
    		else		' otherwise it's ON
    		gosub sub1
    	Goto Loop
    sub1:
    	low 11	 		' Turn Off SAW immediately
    	low 10 			' Turn Off power feed
    	low 9 			' Turn Off Light
    	low 8 			' Turn Off Vacuum
    sub2:
    	high 8	 		' Turn On Vacuum
    	high 9 			' Turn On Light
    	high 10 		' Turn On Power Feed
    	high 11 		' Turn On SAW
    And if you want a blinky Light as well (which now introduces a maximum 10mS delay in this example)...
    	counter=0
    loop:
    		gosub sub2
    		gosub sub1
    	counter=counter+1
    	If Counter=>100 then
    				' approx 1 second toggle
    		toggle portb.5
    		Counter=0
    	Pause 10
    Goto Loop
    sub1:
    sub2:
    Why not also ALIAS your Ports, so they're easier to program... at the start you declare your aliases...
    LED var PortB.5
    then in your program you can write Toggle LED instead of Toggle PortB.5
    The bonus is, if you then decide to move the LED to a different port/pin, you make your change on ONE line of your program, and hey-presto, it doesn't matter how many times you've used LED, they all get reassigned.
    Likewise alias, VACUUM, POWERFEED, LIGHT and SAW and you can then go...
    Low SAW
    Low POWERFEED
    Low LIGHT
    Low VACUUM
    which makes fare more easier program understanding...
    Sep 2006
    Default need the pause
    Thank you for your reply. I do need the delays. If I turn on all the tools at once I will blow a fuse. I need the vac to stay on a few seconds after the saw shuts down to collect the dust. The blinky light just lets me know that it's getting power and to remind me of the hot mains connected to the relays(and lately I've been using it to see the cycle time). Blinky light is not so important but a few one second pauses without the latency would be so nice. How can I get a pause in the main program without the delay at the beginning of the cycle?
    Sep 2006
    Default as per your suggestions...
    I organized it up a bit. The blinky no worky, so I went back to the simple toggle. I aliased everything that I could. Looks better but works the same. Any suggestions?
    '* Name : relay4.BAS
    '* Author : lloyd778
    '* Notice : Copyleft
    '* : No Rights Reserved
    '* Date : 7/12/2006
    '* Version : 1.0.25(+/-)
    '* Notes : for Olimex 4 relay board (PIC I/O) 16F628A
    '* Relay board incantation #25 at least
    ' Use of chicken bones and water buffalo entrails show no
    ' substantial improvement so far.
    pause 50
    define OSC 20
    TRISA = %00010000
    TRISB = %00111001
    LED var portb.5
    Saw var porta.3
    Light var porta.1
    Feed var porta.2
    Vac var porta.0
    Switch var portb.0
    counter var byte
    counter1 var byte
    loop:
    toggle led 'Power LED shows cycle time
    if switch = 1 then ' Switch is OFF
    gosub sub1
    else 'otherwise it's ON
    gosub sub2
    Goto Loop
    sub1:
    low saw
    gosub delay
    low feed
    gosub delay
    low light
    gosub delay
    low vac
    goto loop
    sub2:
    high vac
    gosub delay
    high light
    gosub delay
    high feed
    gosub delay
    high saw
    goto loop
    delay:
    counter=32
    repeat
    pause 50
    counter=counter-1
    until counter=0
    So you put your delays in the turn-on and NOT in the turn-off routines. You won't blow a fuse switching OFF.
    btw... your code is shot! If you call a GOSUB then you terminate the subroutine with a RETURN (see my example), you don't exit back with a GOTO.
    All that happens is you fill up your stack with unpredictable results.
    niels's Avatar
    niels Guest
    Quote Originally Posted by lloyd778
    Your problem is in Sub2. The delays you are using are preventing the switch from being read. What you want to do is check the status of the switch inside the delay routine. If you see the switch go off, jump to Sub1. You need to keep checking the status of the switch - and the easiest place to do this is inside the delay routine itself.
    Sep 2006
    Default That's it...
    Yes, that was exactly my problem all along. Thank you niels.
    Wink Glad you got it working !
    You needed BLACK CAT BONES, and some HIGH JOHN THE CONQUERS ROOT AS WELL! OH AND A CHICKEN FOOT TOO! In liew of actual working code.
    As a woodworker I say; Good Idea ! :-)
    Edit: in retrospect, I think this device should be configured as a slave to the power tools magnetic power switch, Darn those sharp cutters, I think I would not trust a PIC with my fingers!
    niels's Avatar
    niels Guest
    Quote Originally Posted by Joe S.
    I'd trust a PIC- the real question is would you trust the code. A big red mechanical 'kill-power' button in series with the saw wouldn't be a bad idea.
    Talking So the real question is . . .
    Quote Originally Posted by niels
    It is not the pic or code per-se' I don't trust, it's power surges, stray capacitance, you name it . . . gremlins, I'm just saying when my fingers are near the moving parts, I want the isolation of an unpowered relay protecting them. I have more scars than Tim Allens Charactor Tim THE TOOLMAN, and still lucky enough to count to ten.
    Now all that said I stayed up till 4:00 am making a program do exactly what he wanted as the whole thing intrigued the heck out of me! So the real question is :
    Who's having fun out here?
    You may change all the commands in the sub delay with a single pause 1600 (32x50).
    Also you really need to change goto loop in the subs with return as Melanie said.
    Default Code for Lloyd
    Hi Lloyd,
    here is my version as promised to you in private email.
    If anyone uses this code to control machinery they do so at their own risk, I strongly recommend a hard wired power switch.
    '* Name : Saw.BAS ***
    '* Author : [Joe Stokes] ***
    '* Notice : Copyright (c) 2006 Joe Stokes ***
    '* : All Rights Reserved ***
    '* Date : 9/9/06 ***
    '* Version : 1.0 ***
    '* Notes :This program delays vacuum, lights and power feed ***
    '* :For a wood working tool. ***
    '* :You may use this code for your personal devices ***
    '* :without assigning any liability to me, and for non ***
    '* :commercial purposes only. I recommend a positive ***
    '* :mechanical power interrupting device for safety! ***
    '* :Power tools are dangerous, and may inflict grave ***
    '* :injury and or death. Your safety is your personal ***
    '* :responsibility. Please enjoy the use of this code. ***
    '* :It is my gift to you. ***
    start:
    ' Change as applicable to your needs - a faster osc may make saw off happen even
    ' faster, certainly be worth a try. There are ports left over for ???
    @ DEVICE pic16F84A, XT_OSC
    @ DEVICE pic16F84A, WDT_OFF
    @ DEVICE pic16F84A, PWRT_OFF
    @ DEVICE pic16F84A, PROTECT_OFF
    PORTA = %00000001
    PORTB = %00000000
    TRISA = %00000000
    TRISB = %00000000
    symbol Power = PortA.0
    symbol Saw = PortB.0
    symbol Light = PortB.1
    symbol Vacuum = PortB.2
    symbol Feed = PortB.3
    symbol Radio = PortB.4
    symbol Sign = PortB.5
    Flash var byte
    loop: if portA.0 = 0 then 'Switch is off - stop motors if running keep off if off.
    gosub sub1
    if portA.0 = 1 then ' Switch is On
    gosub sub2 ' Begin power on sequence
    goto loop ' endlessly check for power on condition
    sub1: ' This routine stops the motors, lights and returns power
    ' to the shop's radio.
    low Saw ' Turn Off SAW immediately
    low Feed ' Turn Off power feed too
    pause 5000 ' Five seconds for vacuum to remove dust from saw internals
    low saw
    low Light ' Turn Off Light
    low Vacuum ' Turn Off Vacuum
    high Radio ' Turn radio back on
    low Sign ' Turn off Danger sign
    goto loop ' Check for a power on request.
    sub2:
    for Flash = 5 to 0 step -1 ' Change the 5 to any # of flashes you like!
    High Sign ' Turn on Danger Sign reminds family not to distract you!
    pause 250 ' For Next loop flashes sign prior to saw starting
    low Sign
    pause 250
    next
    goto sub3 ' This is how I stopped the flashing light!
    sub3: high sign ' Sign goes on continuously
    low Radio ' Turn off radio, no distractions while cutting.
    if portA.0 = 0 then
    gosub sub1 'check off switch for off request
    high Saw ' Turn On SAW, shaper, other power tool.
    if portA.0 = 0 then
    gosub sub1 ' Check off switch for off request
    pause 1000 ' Time for saw to get up to speed and mains to settle down
    if portA.0 = 0 then
    gosub sub1 ' Check off switch for off request during delay.
    pause 1000 ' Total 2 seconds delay for mains to settle.
    high Vacuum ' Turn On Vacuum
    if portA.0 = 0 then
    gosub sub1 ' Check off switch for off request, keeping it safe
    pause 1000 ' Time for vacuum motor to speed up and mains to settle
    high Light ' Turn On Light
    ' Time for light to to come up to heat and mains to settle
    if portA.0 = 0 then
    gosub sub1 ' Check off switch for off request, still keeping safe.
    high Feed ' Turn On Power Feed, time to do some work!
    goto sub3 ' Loop back to sub3 where off command is located.
    end ' I gotta keep the compiler happy!
  1. 16F628A - Stops if release power switch.
    By dene12 in forum General
    Last Post: - 14th February 2009, 07:57
  2. Old and beyond help ?
    By DavidFMarks in forum mel PIC BASIC Pro
    Last Post: - 11th December 2008, 15:23
  3. need a project for PIC16F84
    By Danish in forum Schematics
    Last Post: - 3rd August 2005, 17:51
  4. Memory Space of the PIC16F84...
    By Tear in forum mel PIC BASIC Pro
    Last Post: - 1st July 2005, 19:55
  5. Problem with saving to EEPROM...
    Last Post: - 1st July 2005, 00:10
