Serial com - AUSART 16F88 - any samples?
Results 1 to 6 of 6
    SWITZERLAND (french speaking)
    Default Serial com - AUSART 16F88 - any samples?
    Hello,
    I would like to transmit serial data using the integrated AUSART module in PIC16F88. THE PIC is directly connected to the PC.
    Each time I start the transmission, the terminal receives some characters (not corresponding to what I send) and the RX counter doesn't stop just as if it would continue to receive datas.
    It looks like a transmission speed error; I then tried all possible baudrates from 300 to 28800 bauds -> no improvement.
    The datasheet indicates to set the TRISB accordingly. Except I/Os, I couldn't find other settings. Are there any?
    Does someone have similar applications examples I could have a look at please?
    Here is my code; unfortunately, it doesn't work well.
    'PORTB.0 is button (INTCON use)
    'PORTB.4 is LED
    'PORTB.5 is TX (PIC fixed) connected to PC's SUB-D9 pin 2
    'GND connected to PC's SUB-D9 pin 5
    'On PC Micro Code Studio's Terminal set to 9600,N,8,1
    OSCCON = %01100000          'Internal RC set to 4MHZ
    TRISB  = %00000101          'PORTB.0 & 2 are Inputs - all others are Outputs
    RCSTA  = %10000000          'Enable serial port (RB2=RX & RB5=TX)
    TXSTA  = %00100000          'Enable Transmit Bit
    SPBRG  = 6                  'Set baudrate to 9600
    Message var word
    Message = 12345
    MAIN:
        if INTCON.1 = 1 then    'Start prog
            INTCON.1 = 0        'Reset INT flag
            high PORTB.4        'Led On = transmission start
            TXREG = Message
            low  PORTB.4        'Led Off = transmission end
        goto MAIN
    Roger
    Feb 2003
    Salt Lake City, Utah USA
    Quote Originally Posted by flotulopex
    [code]...
    ...[code]
    The AUSART uses TRUE format only (idles high). You have hyperterminal set for INVERTED (idles low). I believe your options are:
    a) use the USART with a level converter like the MAX232 between your pin and the PC.
    b) use software inverted serial routines (like serin/serout) instead of the USART - then you can stay directly connected to the PC.
    Paul Borgmeier
    Salt Lake City, UT
    USA
    __________________
    Hello Paul,
    I thought that the AUSART module was replacing an external level converter. So it is not the case?
    What is a TRUE format?
    Roger
    Jun 2005
    Wisconsin
    No, the AUSART doesn't replace a level converter. Most use the AUSART because it can buffer two bytes and you can utilize interrupts with it.
    Paul described it pretty well. True format means that when the lines are not being using they are High. Your computer however lets the lines go low when they are idle.
    So your options are a level converter like the max232, debug, or serin/serout and a few resistors.
    Thank you.
    It's now very clear to me.
    This is most of the problems I face with programming the PICs: I don't fully understand the data sheets...
    Roger
    Jun 2005
    Wisconsin
    Yeah I had that problem too when I started. It takes practice to understand them. I still read a section a few times to make sure my head is wrapped around it before I begin.
  1. Dynamic USB Serial Number (PIC18F4550)
    Last Post: - 16th July 2009, 18:03
  2. 16f88 internal osc 8mhz max serial baudrate ?
    Last Post: - 17th December 2008, 00:27
  3. Replies: 6
    Last Post: - 10th December 2008, 10:00
  4. 16f88 serial out
    By dragons_fire in forum mel PIC BASIC Pro
    Last Post: - 25th May 2006, 00:58
  5. 16F88 Serial Out
    By rwskinner in forum mel PIC BASIC Pro
    Last Post: - 28th February 2006, 20:28
