18F4550 UART and SPI
Results 1 to 4 of 4
    Jan 2006
    Ottawa, Canada
    Question 18F4550 UART and SPI
    Unfortunately the UART Rx and SPI SDO functions on the 18F4550 share the same pin. I can't think of a simple solution which retains both ports without going to a different PIC. Has anyone come across a similar problem &/or have a possible solution?
    Marc
    Possibly reset and reconfigure for other use.
    Norm
    May 2006
    Del Rio, TX, USA
    Use the PBP software solution for one the functions. Both work well, especially with a fast clock rate (which is likely since you are proabably using the 4550's usb, and if you not, other alternative PICs are a better choice).
    For what it's worth, when faced with a similar choice, I used the software SPI and hardware Serial. This allowed me to create an interrupt driven serial buffer for RX. I can recieve data packets "in the background" and then process the data in my main loop as needed. I also "hacked" the PBP SHIFTOUT macro to remove a bunch of 'needless' (in my case) delays (nop and goto $ + 2 commands), increasing the data output rate.
    HTH,
    Jan 2006
    Ottawa, Canada
    Thanks for the excellent feedback Steve!
    I didn't think about using a PBP software solution. I'm using the 4550's USB & trying to get things to work with an ENC28J60. Unfortunately, when I received my Ethernet PICtail daughter card it didn't contain the latest Rev B5 silicon, which supports SCK from DC-20MHz. I will likely upgrade otherwise SCK needs to be >8MHz, as per errata.
    Marc
  1. Hardware SPI with MAX3111E
    By KHsu in forum mel PIC BASIC Pro
    Last Post: - 8th August 2007, 02:42
  2. Servo control / UART / SPI help needed
    By Blackhawk in forum mel PIC BASIC
    Last Post: - 10th November 2006, 04:40
  3. External UART IC
    By Terry in forum General
    Last Post: - 22nd December 2005, 19:01
