Asking for help
Results 1 to 4 of 4
Thread: Asking for help
    Bakari's Avatar
    Bakari Guest
    Cool Asking for help
    Dear Members,
    I am using TLP434A and RLP434A as RF modules for wireless communication. Also I used HT12E encoder and HT12D decoder with them. There was no output from the decoder. I connected the output of the encoder directly to input of the decoder with wire to check whether they are working or not. I found that they are working properly (input to the encoder the same as output from the decoder). I knew that the problem is with the wireless modules.
    In the datasheet it's written that both TX and RX are operating at 315,418 and 433.92 MHz. Can any body tell me how to tune both TX and RX to the same operating frequency?
    Best regards,
    Al Bakari
    the 434 in the part # says the frequency they use. In your case, you don't need to tune them.
    Problem is often the hardware or software.
    Can you post the schematic you're using?
    Bombay, India
    Quote Originally Posted by Bakari
    Dear Members,
    Best regards,
    Al Bakari
    You will need to confirm that both the TLP and RLP modules are of the same frequency. This would be marked either by the ident markings or by a green sticker indicating the frequency it works on. Forget about tuning the modules. Get both of the same frequency.
    Jerson
    kallis's Avatar
    kallis Guest
    thanks for helping out
