16f877a: PCLATH register
Results 1 to 10 of 10
    Wink No Magic here ...
    Hi, Hervé
    Here an example ( ASM source ... )
    REDCYL ;SUB pour lire SEUIL et NCYL
    movlw 1 ;Aller dans LTABLE chercher le SEUIL (negatif)
    ;de ligne rouge
    bcf PCLATH,0 ;LTABLE est la page 2(en h200)
    bsf PCLATH,1 ;donc PCLATH =2
    call LTABLE
    and somewhere further
    LTABLE org h'200' ;Table des delais N =367 - 1500 t/mn(0° avant,soit T/4)
    addwf PCL,f ;sauter au bon endroit h34=opcode pour RETLW
    INCLUDE c:\aepl\Oltab.txt ;ici la LTABLE préalablement générée par le prog. gentab.bas
    The goal is to retrieve a value in a Lookup table ...
    BUT you NEED to know the page number ... where you want to jump to !!!
    So, a solution is to place " manually" your called stubb to a known location ( not "squatted" ) by PbP ... :
    ORG xxxx
    CalledStubb
    PbP example
    'Table des Valeurs d'avance en 200h - longueur Maxi 254 lignes !!!
    asm
    bcf PCLATH,0
    bsf PCLATH,1
    call Table
    Movwf _Avance
    endasm
    and further, at the very top high free program location.
    asm
    ORG 200h
    Table
    movfw _Index
    addwf PCL,F
    Include C:\Documents and Settings\Alain\Mes documents\Avance.txt
    endasm
    No secret there ...
    Bonnes vacances ...
    herve's Avatar
    herve Guest
    Smile 16f877a: 306 message
    Hi everybody,
    Thank you for all your elements. I am waiting for the week-end to analyse them in details (lack of time during the week !).
    Best regards,
    Hervé.
  1. Active low input?
    By CosMecc in forum mel PIC BASIC Pro
    Last Post: - 8th August 2010, 21:31
  2. Can anyone help a newcomer?
    By scopit in forum Schematics
    Last Post: - 20th October 2009, 10:23
  3. PIC16F877A pwm use for IR transmission
    By mcbeasleyjr in forum General
    Last Post: - 11th July 2009, 19:51
  4. MX7705 or AD7705 experience
    By FM11 in forum mel PIC BASIC Pro
    Last Post: - 12th January 2006, 22:54
  5. Problems with 16F877A code
    By NightHawk2 in forum mel PIC BASIC Pro
    Last Post: - 20th August 2003, 02:36
