16f877a: PCLATH register
Results 1 to 10 of 10
    herve's Avatar
    herve Guest
    Unhappy 16f877a: message 306 / PCLATH
    Hello Dave and Alain,
    I am not using any "BRANCH procedure". My program is only using a lot of "GOTO" and "CALL" instructions. People explained me that this large number of "GOTO" and "CALL" is the reason why there is the message 306 (Crossing page boundary -- ensure page bits are set): the pic program memory (where my program is saved) is divided into pages due to limitation in the program counter size that can't carry the whole address bits for the whole memory. My program may have exceeded the size of one page so it crossed the page boundries to the next page. So the pc (program counter) overflowed.
    The solution would be to adjust PCLATH register.
    That is why I would like someone to give me an example of PCLATH use, through a short program, in order that I could know how to do with this PCLATH.
    If you could help me, I thank you in advance,
    Best regards,
    Hervé.
    Feb 2003
    Salt Lake City, Utah USA
    Smile
    Quote Originally Posted by herve
    ...My program is only using a lot of "GOTO" and "CALL" instructions. ...
    herve,
    You are missing the (same) message from the people trying to help you. Everybody gets the 306 warning message (which is not an error message, just a warning) if their program crosses a page boundary – everybody. Are you just getting the warning or is your program not doing what you expect? If it is the latter, then move your ASM routines to the first code page and makes sure this routine does not jump forward across a page boundary. If your ASM routine “intends” to jump forward across a page boundary, you can adjust bits 3 and 4 of PCLATCH just before the ASM CALL or GOTO. Personaly, I wouldn't go there unless you are well versed in ASSEMBLY programming. Again, see:
    http://www.picbasic.co.uk/forum/showthread.php?t=555
    Good Luck
    Paul Borgmeier
    Salt Lake City, UT
    USA
    __________________
    Wink No Magic here ...
    Hi, Hervé
    Here an example ( ASM source ... )
    REDCYL ;SUB pour lire SEUIL et NCYL
    movlw 1 ;Aller dans LTABLE chercher le SEUIL (negatif)
    ;de ligne rouge
    bcf PCLATH,0 ;LTABLE est la page 2(en h200)
    bsf PCLATH,1 ;donc PCLATH =2
    call LTABLE
    and somewhere further
    LTABLE org h'200' ;Table des delais N =367 - 1500 t/mn(0° avant,soit T/4)
    addwf PCL,f ;sauter au bon endroit h34=opcode pour RETLW
    INCLUDE c:\aepl\Oltab.txt ;ici la LTABLE préalablement générée par le prog. gentab.bas
    The goal is to retrieve a value in a Lookup table ...
    BUT you NEED to know the page number ... where you want to jump to !!!
    So, a solution is to place " manually" your called stubb to a known location ( not "squatted" ) by PbP ... :
    ORG xxxx
    CalledStubb
    PbP example
    'Table des Valeurs d'avance en 200h - longueur Maxi 254 lignes !!!
    asm
    bcf PCLATH,0
    bsf PCLATH,1
    call Table
    Movwf _Avance
    endasm
    and further, at the very top high free program location.
    asm
    ORG 200h
    Table
    movfw _Index
    addwf PCL,F
    Include C:\Documents and Settings\Alain\Mes documents\Avance.txt
    endasm
    No secret there ...
    Bonnes vacances ...
    herve's Avatar
    herve Guest
    Smile 16f877a: 306 message
    Hi everybody,
    Thank you for all your elements. I am waiting for the week-end to analyse them in details (lack of time during the week !).
    Best regards,
    Hervé.
  1. Active low input?
    By CosMecc in forum mel PIC BASIC Pro
    Last Post: - 8th August 2010, 21:31
  2. Can anyone help a newcomer?
    By scopit in forum Schematics
    Last Post: - 20th October 2009, 10:23
  3. PIC16F877A pwm use for IR transmission
    By mcbeasleyjr in forum General
    Last Post: - 11th July 2009, 19:51
  4. MX7705 or AD7705 experience
    By FM11 in forum mel PIC BASIC Pro
    Last Post: - 12th January 2006, 22:54
  5. Problems with 16F877A code
    By NightHawk2 in forum mel PIC BASIC Pro
    Last Post: - 20th August 2003, 02:36
