16f877a: PCLATH register
Results 1 to 10 of 10
    herve's Avatar
    herve Guest
    Question 16f877a: PCLATH register
    Could somebody give me a simple example, showing how to use " PCLATH register", in a short program. My objective is to solve the message 306: Crossing page boundary - ensure page bits are set", which appears in my program. My program is done with MPLAB IDE V6.60.
    Thank you in advance,
    Best regards,
    Hervé.
    Hi,Herve
    You can forget about Message 306 ... PBasic cares for you !!!
    It can be cancelled using :
    @ Errorlevel -306
    at the top of your program ...
    OR using PM Compiler ... !!!
    Now PCLATH permits to use a larger adressing range than an asm CALL allows, Look at fig 2.3 p 19 of the Datasheet : it explains the different BANKS of memory. PCLATH permits to choose one of these Banks.
    a look at page 32 will show you how addressing is done ...
    Good readings
    herve's Avatar
    herve Guest
    Wink 16f877a: 306 message
    Hello Acetronics,
    I have already used "ERRORLEVEL - 306". It was OK to suppress the message, but when I launched the program, I faced with problems at the level where the message 306 was indicated (before the addition of "ERRORLEVEL-306"). So, I concluded that I could not ignore this message.
    I am going to analyse the datasheet, in accordance with your proposal, but could you give me a short example of program using PCLATH register, in order that it completes my analysis efficiency ?
    Best regards,
    Hervé.
    Feb 2003
    Salt Lake City, Utah USA
    Smile
    Paul Borgmeier
    Salt Lake City, UT
    USA
    __________________
    Wink THE good question ...
    Quote Originally Posted by herve
    Hello Acetronics,
    I faced with problems at the level where the message 306 was indicated , ... but could you give me a short example of program using PCLATH register, in order that it completes my analysis efficiency ?
    Hervé.
    Hi, Hervé
    Using pure PbP would never involve such problems ... sooooooo, WHAT do you do and want to do here ????????????????????
    My crystal ball is gone for holidays ...
    herve, The message is just a warning. As long as you are not using the BRANCH statement you should be OK. If you are using the BRANCH statement in your program then change it to BRANCHL. This is the BranchLong statement and is used when branching to other parts of your program that are not in the same page (crossing page boundries).
    herve's Avatar
    herve Guest
    Unhappy 16f877a: message 306 / PCLATH
    Hello Dave and Alain,
    I am not using any "BRANCH procedure". My program is only using a lot of "GOTO" and "CALL" instructions. People explained me that this large number of "GOTO" and "CALL" is the reason why there is the message 306 (Crossing page boundary -- ensure page bits are set): the pic program memory (where my program is saved) is divided into pages due to limitation in the program counter size that can't carry the whole address bits for the whole memory. My program may have exceeded the size of one page so it crossed the page boundries to the next page. So the pc (program counter) overflowed.
    The solution would be to adjust PCLATH register.
    That is why I would like someone to give me an example of PCLATH use, through a short program, in order that I could know how to do with this PCLATH.
    If you could help me, I thank you in advance,
    Best regards,
    Hervé.
    Feb 2003
    Smile
    ...My program is only using a lot of "GOTO" and "CALL" instructions. ...
    herve,
    You are missing the (same) message from the people trying to help you. Everybody gets the 306 warning message (which is not an error message, just a warning) if their program crosses a page boundary – everybody. Are you just getting the warning or is your program not doing what you expect? If it is the latter, then move your ASM routines to the first code page and makes sure this routine does not jump forward across a page boundary. If your ASM routine “intends” to jump forward across a page boundary, you can adjust bits 3 and 4 of PCLATCH just before the ASM CALL or GOTO. Personaly, I wouldn't go there unless you are well versed in ASSEMBLY programming. Again, see:
    http://www.picbasic.co.uk/forum/showthread.php?t=555
    Good Luck
    Paul Borgmeier
    Salt Lake City, UT
    USA
    __________________
    Wink No Magic here ...
    Hi, Hervé
    Here an example ( ASM source ... )
    REDCYL ;SUB pour lire SEUIL et NCYL
    movlw 1 ;Aller dans LTABLE chercher le SEUIL (negatif)
    ;de ligne rouge
    bcf PCLATH,0 ;LTABLE est la page 2(en h200)
    bsf PCLATH,1 ;donc PCLATH =2
    call LTABLE
    and somewhere further
    LTABLE org h'200' ;Table des delais N =367 - 1500 t/mn(0° avant,soit T/4)
    addwf PCL,f ;sauter au bon endroit h34=opcode pour RETLW
    INCLUDE c:\aepl\Oltab.txt ;ici la LTABLE préalablement générée par le prog. gentab.bas
    The goal is to retrieve a value in a Lookup table ...
    BUT you NEED to know the page number ... where you want to jump to !!!
    So, a solution is to place " manually" your called stubb to a known location ( not "squatted" ) by PbP ... :
    ORG xxxx
    CalledStubb
    PbP example
    'Table des Valeurs d'avance en 200h - longueur Maxi 254 lignes !!!
    asm
    bcf PCLATH,0
    bsf PCLATH,1
    call Table
    Movwf _Avance
    endasm
    and further, at the very top high free program location.
    asm
    ORG 200h
    Table
    movfw _Index
    addwf PCL,F
    Include C:\Documents and Settings\Alain\Mes documents\Avance.txt
    endasm
    No secret there ...
    Bonnes vacances ...
    herve's Avatar
    herve Guest
    Smile 16f877a: 306 message
    Hi everybody,
    Thank you for all your elements. I am waiting for the week-end to analyse them in details (lack of time during the week !).
    Best regards,
    Hervé.
  1. Active low input?
    By CosMecc in forum mel PIC BASIC Pro
    Last Post: - 8th August 2010, 20:31
  2. Can anyone help a newcomer?
    By scopit in forum Schematics
    Last Post: - 20th October 2009, 09:23
  3. PIC16F877A pwm use for IR transmission
    By mcbeasleyjr in forum General
    Last Post: - 11th July 2009, 18:51
  4. MX7705 or AD7705 experience
    By FM11 in forum mel PIC BASIC Pro
    Last Post: - 12th January 2006, 21:54
  5. Problems with 16F877A code
    By NightHawk2 in forum mel PIC BASIC Pro
    Last Post: - 20th August 2003, 01:36
