Pwm
Results 1 to 5 of 5
Thread: Pwm
    JARI NETWORKS's Avatar
    JARI NETWORKS Guest
    Default Pwm
    Can someone tell me how to program a pic16f628a in PBP with a frequence of 0.3 Hz??
    .3 Hz is impossible with the hardware PWM module. My best bet will be to create one using the Timer interrupts.... but ...ahem... 0.3 HZ is really slow... what is the purpose of a so slow frequency? Maybe a old 555 could do the job.
    .3 KHZ it's possible @4MHZ
    hpwm 1,255,300
    JARI NETWORKS Guest
    my purpose was to fade in and out 3 leds in 1 sec. but maybe is it possible to do it with 3 ports of a pic16f628a chip and a cyclus of 1 sec.
    so the frequency don't really matter... anyway @.3Hz you'll see them flash so. over hundreds HZ will do the job.
    You should look at Multi_SSPWM from Darrel Taylor. it should be enough to start.. and probably finish the whole thing.
    http://www.pbpgroup.com/modules/wfse...p?articleid=12
    JARI NETWORKS Guest
    OK thanks for the link.
    Greets Jan
  1. Half-bridge PWM with a 16F684 ?
    Last Post: - 17th January 2010, 23:18
  2. Variable PWM PIC18F2431
    By trr1985 in forum mel PIC BASIC Pro
    Last Post: - 12th June 2009, 07:03
  3. PWM: Vernacular/Function (Newbee)
    By TerryN in forum mel PIC BASIC Pro
    Last Post: - 3rd July 2008, 17:58
  4. PWM setting PIC16F887
    By Gevo in forum mel PIC BASIC Pro
    Last Post: - 12th June 2008, 08:24
  5. Tidying Up PWM Routine
    Last Post: - 21st February 2005, 01:26
