PICs on a bus . . . ?
Results 1 to 12 of 12
    Mentor, Ohio
    Smile
    Hi Russ,
    I recently built 2 systems that have 20 PICs reporting to 1 PIC on a 2 wire buss. One is Busy and the other is data. They work great!
    Let me know if you need more info on this type of system.
    BobK
    Omaha, Nebraska USA
    Default Thanks, Melanie and Bob
    Bob, I've sent you a PM on this so we won't clutter up the forum. I'll look forward to hearing from you.
    Melanie, thanks for the reminder on pullup(s). I'm using the 16F87xA devices (so far), and the only open drain I see in the data sheet is RA4. Being a fussy creature of habit, I'll probably want to put 4.7K pullups on anything that resembles a parallel bus . . .
    Russ
    N0EVC, xWB6ONT, xWN6ONT
    "Easy to use" is easy to say.
    Mar 2005
    Iowa, USA
    Default Ot
    Sorry, but I had to chime in.... Does this sound like a bad Samuel L. Jackson movie to anyone else? Pics on a Bus..... Snakes on a Plane.
    Wisdom is knowing what path to take next... Integrity is taking it.
    Ryan Miller
    Bombay, India
    Quote Originally Posted by rhino
    Just taking it a lil' further, how about a Rhino in soup?
    Hey I'm only jokin. So, don't get serious.
    Jerson
    Lightbulb Not so hastey . . .
    Quote Originally Posted by RussMartin
    All the jokes aside, . . .
    Lots of Noobies out here looking to learn from posts such as this - It's not clutter to us, Thank You.
    Omaha, Nebraska USA
    Default Sorry, JoeS
    My apologies--I wasn't intending to be rude! I sent a private message to Bob merely to request more details. I'm sure he would be happy to share with all . . .
    Russ
    Sep 2005
    Campbell, CA
    Measuring AC current is not as easy as it seems. I assume that the voltage is something above 60V.
    Although the voltage waveform of your AC might be a sine wave, the current waveform seldom is. Unless your load is purely resistive, you cannot measure current by taking a percentage of the peak value output of a current transformer or Hall-effect device. If you are measuring "mains" voltage, then measuring the current by sensing voltage drop across a resistor is probably not an option. A Hall-effect device is usually the best option.
    So, you will probably need to measure RMS current.
    In order to get decent accuracy, you will have to sample the current waveform at least 10 times in each half-cycle, multiply each sample value by itself (square it), then average the samples by adding the squares together over a period (at least one cycle) and dividing by the number of samples, and finally taking the square root of the average.
    You *can* do this, and I don't want to sound like a broken record - but 18F parts are better at most everything!
    That said, I have used an 18F8723 to measure 4 channels of RMS current with good accuracy using Allegro Hall-effect current sensors.
    The chip was very busy, and was running at 40Mhz.
    Charles Linquist
    May 2008
    Italy
    Are you sure?
    Al.
    Sep 2005
    Campbell, CA
    If you have a better idea, I'm open to it. Yes, you can sample slowly if you can tolerate a longer-term average (like you would need to display on an LCD). I realized that even with low sample rates, I would sample every part of the waveform eventually. But I needed an "electronic circuit breaker" that had to respond on a cycle-by-cycle basis.
    I proved that I could respond in one cycle by connecting a bridge rectifier + resistor + FET across the load and connecting the gate of the FET to a pin on a PIC development board then bringing the the gate high for 17 ms. It worked and the circuits are in the hands of a happy (and very demanding) military customer.
    Charles Linquist
  1. RS485 bus - starting probem
    By wurm in forum mel PIC BASIC Pro
    Last Post: - 27th January 2010, 13:35
  2. Communicating between two PICs over DC bus
    Last Post: - 7th May 2009, 12:57
  3. Retrieving infos from multiple PICs on a bus/chain
    Last Post: - 15th October 2007, 04:42
  4. Need the code to write to a memory
    By Hamlet in forum General
    Last Post: - 20th August 2007, 00:22
  5. Two pics in a I2C bus?
    By robert0 in forum mel PIC BASIC Pro
    Last Post: - 4th January 2006, 13:44
