PICs on a bus . . . ?
Results 1 to 12 of 12
    Omaha, Nebraska USA
    Default PICs on a bus . . . ?
    Given: One PIC is "the boss", one port is defined as output. Some x others, "slaves", each having one port defined as input. They share an 8-bit parallel bus.
    Any issues? And what is the fanout limitation?
    Russ
    N0EVC, xWB6ONT, xWN6ONT
    "Easy to use" is easy to say.
    In theory, dozens... since the master PIC can sink/source 25mA and the slaves have relatively high impedance (2K-10K) inputs. However in practice this will depend on the Data Transfer Speed and the total loaded circuit capacitance. You 'may' need some Pull-Up's on the Bus. If you're breadboarding, you'll discover if it's needed, if you're laying down a PCB board as a starter, there's no harm in adding the holes for a SIL Resistor pack in case it's needed. I can confirm FOUR PICS on a (small two-wire) Bus without problems. Watch you don't use a Port on the Master which has an Open-Drain pin - otherwise you WILL need that external Resistor.
    Mentor, Ohio
    Smile
    Hi Russ,
    I recently built 2 systems that have 20 PICs reporting to 1 PIC on a 2 wire buss. One is Busy and the other is data. They work great!
    Let me know if you need more info on this type of system.
    BobK
    Omaha, Nebraska USA
    Default Thanks, Melanie and Bob
    Bob, I've sent you a PM on this so we won't clutter up the forum. I'll look forward to hearing from you.
    Melanie, thanks for the reminder on pullup(s). I'm using the 16F87xA devices (so far), and the only open drain I see in the data sheet is RA4. Being a fussy creature of habit, I'll probably want to put 4.7K pullups on anything that resembles a parallel bus . . .
    Russ
    Mar 2005
    Iowa, USA
    Default Ot
    Sorry, but I had to chime in.... Does this sound like a bad Samuel L. Jackson movie to anyone else? Pics on a Bus..... Snakes on a Plane.
    Wisdom is knowing what path to take next... Integrity is taking it.
    Ryan Miller
    Bombay, India
    Quote Originally Posted by rhino
    Just taking it a lil' further, how about a Rhino in soup?
    Hey I'm only jokin. So, don't get serious.
    Jerson
    Lightbulb Not so hastey . . .
    Quote Originally Posted by RussMartin
    All the jokes aside, . . .
    Lots of Noobies out here looking to learn from posts such as this - It's not clutter to us, Thank You.
    Omaha, Nebraska USA
    Default Sorry, JoeS
    My apologies--I wasn't intending to be rude! I sent a private message to Bob merely to request more details. I'm sure he would be happy to share with all . . .
    Russ
  1. RS485 bus - starting probem
    By wurm in forum mel PIC BASIC Pro
    Last Post: - 27th January 2010, 13:35
  2. Communicating between two PICs over DC bus
    Last Post: - 7th May 2009, 12:57
  3. Retrieving infos from multiple PICs on a bus/chain
    Last Post: - 15th October 2007, 04:42
  4. Need the code to write to a memory
    By Hamlet in forum General
    Last Post: - 20th August 2007, 00:22
  5. Two pics in a I2C bus?
    By robert0 in forum mel PIC BASIC Pro
    Last Post: - 4th January 2006, 13:44
