Condition testing
Results 1 to 5 of 5
    jtburnham's Avatar
    jtburnham Guest
    Default Condition testing
    I'm using PBPro and I hoping someone can answer a fairly simple question for me. I want to test for 1 or more set bits on port a.
    For single bit testing, this doesn't work -
    IF (porta AND %00000001) THEN ...
    This also doesn't work -
    IF (porta AND %00000001) = 1 THEN ...
    For multiple bit testing, this doesn't work -
    IF (porta AND %00000101) THEN ...
    IF (porta AND %00000101) = 1 THEN ...
    Is there another way besides IF (porta.0 = 1 AND porta.3 = 1) THEN... to test for set bits? I thought AND was an accepted test for byte testing.
    Thank you for your help.
    Jim Burnham
    Your logic is flawed because for example if bit PortA.2 is set then the equation would equal 4 and not 1.
    Try this instead...
    If (PortA and %00000101)<>0 then
    Inside the parenthesis the test is logical but outside is a comparison of two numbers. It is allways 'false' condition...
    jtburnham's Avatar
    jtburnham Guest
    Quote Originally Posted by Melanie
    Your logic is flawed ...
    My wife frequently makes the same observation.
    I do see where I was going wrong.
    Thank you all.
    Jim
    See? As always women are addressing (here Melanie...) this kind of problems!
  1. HARDWARE I2C SAMPLE CODE question
    Last Post: - 16th June 2009, 22:07
  2. Auto testing bulbs
    Last Post: - 2nd September 2008, 11:53
  3. PIC16F877 I2C programme
    By cooqo in forum mel PIC BASIC
    Last Post: - 21st April 2008, 11:02
  4. Testing LCD's
    By david miles in forum General
    Last Post: - 29th January 2008, 22:35
  5. Testing PortB pin
    By jrt4fun in forum mel PIC BASIC Pro
    Last Post: - 2nd August 2005, 08:08
