DCF77 decode
Results 1 to 6 of 6
Thread: DCF77 decode
    Jul 2006
    Lazio, Italy
    Default DCF77 decode
    Please I need a DCF77 decode routine for a Pic. Do you have? Thanks
    Oct 2003
    holland
    Here is the spec
    http://www.prog-link.com/dcf77/dcf77-contents.html
    and in the attagement is what I made once
    Jul 2006
    Lazio, Italy
    Default Thanks
    Thanks for your help, but your routine seems do not work. Can you give me more informations please? Thanks
    Oct 2003
    holland
    I just made a trial with the software and tested it. Look what happens!
    I think you made some typing errors.
    Oct 2013
    Default Re: DCF77 decode
    if someone tried this code with dcf77.5 receiver buyed in Pollin.de store. The display show only message WAIT FOR STARTBIT and in the second row counter counts from 1 to 120 in the interval of one second.
    I use PIC16f876A and 4MHz quartz.
    Oct 2013
    Today I build a little buffer with CD4011 chip and now i got a readings of DCF77.5 signal but there is a one problem.Some times i have a correct decoded values of clock,day,year but mostly the values are incorrect,because of bad signal or lose of synchronization.Is it possible to make a routine in this code that checked whether all data is received in proper form and that there was no loss of synchronization.
  1. How to decode an SMS which looks like this ...
    Last Post: - 8th October 2009, 01:26
  2. RC5 decode on a 10F + Question
    By ultiblade in forum mel PIC BASIC Pro
    Last Post: - 11th September 2008, 09:20
  3. IR decode problem "hitachi TV remote"
    Last Post: - 13th March 2006, 16:29
  4. How to decode IR Hitachi remate (TV) pls help
    Last Post: - 4th March 2006, 12:55
  5. DCF77 and PICBasic
    By mdogsa in forum General
    Last Post: - 14th August 2004, 22:20
