Ambient Light Level Monitoring
Results 1 to 9 of 9
    Mar 2005
    I have setup an LDR with Op-Amp and it works just fine. I have been looking at using the TI parts and have some on order but may go with the LDR if I can generate a curve to allow voltage to lumens.
    I have been thinking of mounting the board in an enclosure with an electronics ballast then start with total darkness then generate a curve from 0-100% but this does not follow ambient lighting.
    Any thoughts?
    Thanks to all that has replied,
    Scott
    scottl, I have used 4 of the TSL230's in a sun tracking sensor unit for a solar furnace with great success. All you need to do is count the pulses gererated by the units. No need for linearization or amplifiers. The Texas Advanced Optical Systems (TAOS) TSL230 sensor precisely measures light using an array of photodiodes, with an output of digital square waves. The TSL230 has an input dynamic range of 160dB; that is, it can measure light over a range of 100,000,000-to-1. Parallax still has them for $4.95 each.
    Mar 2005
    Dave,
    This look like this will do the trick. I am going to order a couple to try and I will let you everyone know the results.
    Mouser also has stock at $4.75!
    Scott
    I just used an LDR in a simple voltage divider configuration, and it works very well.
    Use the circuit Sayzer's given minus the transistor; feed the junction of the LDR and the resistor directly to the pic.
    Anand
    Mar 2005
    Thanks for the reply! I will give it a shot this week.
    Scott
  1. Replies: 24
    Last Post: - 1st December 2009, 08:01
  2. Stairwell light code from BS1 to PHP2.50a
    By vtt-info in forum mel PIC BASIC Pro
    Last Post: - 21st December 2007, 17:32
  3. 16F877A problem: "coupled" digital values
    By Lupo83 in forum General
    Last Post: - 4th December 2007, 12:46
  4. A/D on 16F767 for light tracking.
    By Ryan7777 in forum mel PIC BASIC Pro
    Last Post: - 10th November 2007, 05:56
  5. Using LEDs as light sensors
    Last Post: - 30th December 2006, 22:19
