Toni,
i can comfirm that pbp2.45 does not have that problem
Although i tested the Read/Write command on a 18f452 and i am using pbp2.45 and it works below is the code i am not quite sure how to do this using the DATA@ command.
i am presently trying to work out how to do this
Best Regards
Isaac
DEFINE LOADER_USED 1 ' uses a bootloader
@ __CONFIG _CONFIG1H, _OSCS_OFF_1H & _HS_OSC_1H
Define OSC 20
clear
DEFINE LCD_DREG PORTD ' Use Portd for LCD Data
DEFINE LCD_DBIT 4 ' Use Upper(4) 4 bits of Port
' PORTD-4 thru PORTD-7 connects to
' LCD DB4 thru LCD DB-7 respectively
DEFINE LCD_RSREG PORTE ' PORTE for RegisterSelect (RS) bit
DEFINE LCD_RSBIT 0 ' PORTE-0 pin for LCD's RS line
DEFINE LCD_EREG PORTE ' PORTE for Enable (E) bit
DEFINE LCD_EBIT 1 ' PORTE-1 pin for LCD's E line
DEFINE LCD_BITS 4 ' Using 4-bit bus
DEFINE LCD_LINES 2 ' Using 2 line Display
DEFINE LCD_COMMANDUS 2000 ' Command Delay (uS)
DEFINE LCD_DATAUS 50 ' Data Delay (uS)
' ** Define LCD Control Constants **
I CON 254 ' Control Byte
Clr CON 1 ' Clear the display
Line1 CON 128 ' Point to beginning of line 1
Line2 CON 192 ' Point to beginning of line 2
' Software Defines
' ** Declare the Variables **
Temp VAR word ' General Purpose
Data_Out VAR word ' Data read from the Eeprom
Data_In VAR word ' Data written to the Eeprom
address VAR word' Address
' Initialise Hardware
ADCON1=7
TRISA=%00000000
TRISB=%00000000
TRISC=%10000000
TRISD=%00000000
Pause 1000
lcdout I,Clr:Pause 30
lcdout I,Line1," 18F452 TEST "
lcdout I,Line2+2,"..Power On.. !!"
Pause 1000 '
Data_Out=0: Data_In =0: Temp =0
'WRITE SUB
For address = 0 TO 100 STEP 2 ' Loop 50 times
Data_In =Temp ' Data_In is data for EPPROM
WRITE address,Data_In.LowByte
WRITE (address+1),Data_In.HighByte
Pause 10 ' Delay 10ms after each write
Temp =Temp + 1000 ' Add 1000 to the previous value
Next address
loop:
'READ SUB
READ address,Data_Out.LowByte
READ (address+1),Data_Out.HighByte
lcdout I,Line1+2," Eprom Values :"
lcdout I,Line2+2,#address,": ",#Data_Out ' Display Eprom Data
Pause 1000
Next address
GoTo loop
